$ arduino-cli core update-index
- Install the Arduino core for Mbed:
$ arduino-cli core install arduino:mbed
- From Edge Impulse, export as C++ library using TensorFlow Lite, and place the output (three folders) in the
src/ directory.
- Run the following script to change the structure of the SDK to something the Arduino build tools understand:
rm -rf ./src/edge-impulse-sdk/utensor/CMakeFiles/
rm -rf ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/mbed/
rm -rf ./src/edge-impulse-sdk/porting/posix/
rm -rf ./src/edge-impulse-sdk/classifier/ei_run_classifier_c*
rm -rf ./src/edge-impulse-sdk/utensor/TESTS/
rm -rf ./src/edge-impulse-sdk/utensor/examples/
rm -f ./src/edge-impulse-sdk/CMSIS-DSP/Source/TransformFunctions/arm_bitreversal2.S
rm -rf ~/Library/Arduino15/packages/arduino/hardware/mbed/1.1.4/cores/arduino/mbed/features/unsupported/dsp/
rm -rf ./src/edge-impulse-sdk/CMSIS-DSP/Source/MatrixFunctions/*.c
rm -rf ./src/edge-impulse-sdk/CMSIS-DSP/Source/TransformFunctions/*.c
rm -rf ./src/edge-impulse-sdk/CMSIS-DSP/Source/CommonTables/*.c
rm -rf ./src/edge-impulse-sdk/CMSIS-DSP/Source/FilteringFunctions/*.c
rm -rf ./src/edge-impulse-sdk/CMSIS-DSP/Source/StatisticsFunctions/*.c
rm -rf ./src/edge-impulse-sdk/CMSIS-DSP/Source/BasicMathFunctions/*.c
rm -rf ./src/edge-impulse-sdk/CMSIS-DSP/Source/SupportFunctions/*.c
rm -rf ./src/edge-impulse-sdk/CMSIS-DSP/Source/DistanceFunctions/*.c
rm -rf ./src/edge-impulse-sdk/CMSIS-DSP/Source/ControllerFunctions/*.c
rm -rf ./src/edge-impulse-sdk/CMSIS-DSP/Source/FastMathFunctions/*.c
rm -rf ./src/edge-impulse-sdk/CMSIS-DSP/Source/BayesFunctions/*.c
rm -rf ./src/edge-impulse-sdk/CMSIS-DSP/Source/SVMFunctions/*.c
rm -rf ./src/edge-impulse-sdk/CMSIS-DSP/Source/ComplexMathFunctions/*.c
mv ./src/edge-impulse-sdk/tensorflow/lite/kernels/kernel_util.cc ./src/edge-impulse-sdk/tensorflow/lite/kernels/kernel_util.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/kernels/internal/quantization_util.cc ./src/edge-impulse-sdk/tensorflow/lite/kernels/internal/quantization_util.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/conv.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/conv.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/depthwise_conv.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/depthwise_conv.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/softmax.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/softmax.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/all_ops_resolver.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/all_ops_resolver.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/round.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/round.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/strided_slice.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/strided_slice.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/prelu.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/prelu.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/split.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/split.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/fully_connected.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/fully_connected.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/mul.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/mul.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/dequantize.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/dequantize.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/unpack.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/unpack.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/arg_min_max.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/arg_min_max.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/reshape.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/reshape.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/activations.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/activations.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/logistic.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/logistic.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/ceil.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/ceil.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/elementwise.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/elementwise.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/pooling.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/pooling.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/floor.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/floor.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/svdf.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/svdf.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/maximum_minimum.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/maximum_minimum.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/pack.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/pack.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/comparisons.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/comparisons.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/quantize.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/quantize.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/logical.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/logical.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/neg.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/neg.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/add.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/kernels/add.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/test_helpers.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/test_helpers.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/simple_memory_allocator.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/simple_memory_allocator.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/micro_error_reporter.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/micro_error_reporter.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/micro_optional_debug_tools.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/micro_optional_debug_tools.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/debug_log_numbers.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/debug_log_numbers.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/micro_interpreter.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/micro_interpreter.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/memory_planner/greedy_memory_planner.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/memory_planner/greedy_memory_planner.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/memory_planner/linear_memory_planner.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/memory_planner/linear_memory_planner.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/micro_utils.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/micro_utils.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/micro_mutable_op_resolver.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/micro_mutable_op_resolver.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/micro_allocator.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/micro_allocator.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/memory_helpers.cc ./src/edge-impulse-sdk/tensorflow/lite/experimental/micro/memory_helpers.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/core/api/error_reporter.cc ./src/edge-impulse-sdk/tensorflow/lite/core/api/error_reporter.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/core/api/tensor_utils.cc ./src/edge-impulse-sdk/tensorflow/lite/core/api/tensor_utils.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/core/api/flatbuffer_conversions.cc ./src/edge-impulse-sdk/tensorflow/lite/core/api/flatbuffer_conversions.cpp
mv ./src/edge-impulse-sdk/tensorflow/lite/core/api/op_resolver.cc ./src/edge-impulse-sdk/tensorflow/lite/core/api/op_resolver.cpp
mv ./src/edge-impulse-sdk/porting/mbed/debug_log.cc ./src/edge-impulse-sdk/porting/mbed/debug_log.cpp
- Add the following sketch which invokes the inferencing SDK to classify a sample:
using namespace mbed;
#include "ei_run_classifier.h"
float features[] = {
1.5100, 3.7600, 10.2400, 1.8200, 5.4800, 9.9500, 2.0400, 6.9800, 10.2900, 1.5100, 6.5000, 9.9300, 0.2500, 4.6300, 10.0000, -1.2100, 2.4600, 10.0500, -1.2100, 2.4600, 10.0500, -2.1000, 1.0100, 9.7800, -2.2600, -0.8700, 10.1400, -1.6200, -0.8400, 10.1600, -0.9100, -0.2000, 10.2300, -0.3500, 0.3600, 10.0600, 1.8100, 0.8200, 9.4900, 1.8100, 0.8200, 9.4900, 2.5600, -1.9800, 9.1300, 2.0700, -4.9000, 10.1000, 0.3800, -7.3400, 10.5400, 0.6000, -5.7300, 9.9900, 0.8400, -3.4300, 10.1800, 1.0900, -3.7900, 9.7000, 1.0900, -3.7900, 9.7000, 1.3500, -4.2600, 10.0400, 1.6000, -3.5800, 9.9400, 1.2400, -1.3200, 9.6000, 1.3500, -1.2600, 9.7600, 1.1300, -1.9200, 10.1400, 0.3200, -0.7300, 10.2100, 0.3200, -0.7300, 10.2100, 2.9500, -0.8200, 9.9000, 3.4400, 2.1700, 10.0200, 2.5300, 3.6700, 10.1800, 1.6400, 3.9100, 9.7000, 0.5100, 4.5900, 9.9800, 0.1600, 5.0400, 10.0900, 0.1600, 5.0400, 10.0900, 1.0600, 4.7000, 10.3300, 1.5900, 4.4000, 9.9400, 0.3900, 3.0200, 10.2600, 0.1000, 1.7800, 9.9900, -0.3700, 1.2800, 10.1500, -0.3700, 1.2800, 9.9100, -0.2000, 1.5200, 9.9100, -0.3300, 2.5200, 9.9600, 0.3600, 3.2800, 10.0300, 0.2300, 3.3400, 10.3300, -1.1100, 1.7400, 9.9100, -2.6200, -1.1100, 10.2900, -2.6200, -1.1100, 10.2900, -1.8700, -3.1100, 10.0000, -2.0900, -4.0700, 9.9400, -2.1200, -4.0100, 10.2100, -1.4100, -4.2000, 10.0900, -1.6900, -3.5100, 10.1500, 0.3500, -3.0000, 10.1300, 0.3500, -3.0000, 10.1300, -0.0500, -2.7300, 9.9400, 0.0200, -3.1800, 10.0700, 0.9200, -1.9000, 10.1700, 2.2100, -1.8700, 9.9700, 2.9500, -2.5600, 9.9800, 1.9400, -3.2000, 10.2200, 1.9400, -3.2000, 10.2200, 1.3400, -2.5700, 9.6700, 1.4300, -0.1200, 10.1100, 1.4300, 1.7100, 9.8200, 1.0400, 3.2000, 9.7500, 1.4900, 4.2400, 10.0100, 0.4400, 4.5200, 9.9900, 0.4400, 4.5200, 9.9900, 0.2000, 4.6100, 10.0700, -1.7500, 4.5500, 10.1900, -2.7800, 3.8400, 9.9700, -2.4100, 6.8100, 10.2100, -2.6200, 6.6100, 10.0100, -2.5500, 3.6900, 9.9800, -2.5500, 3.6900, 9.9800, -1.5300, -0.1100, 10.0300, -0.7700, -1.3900, 10.1900, -0.7500, -0.2500, 9.9300, -0.5000, 1.5100, 10.2800, -0.3600, 1.0900, 9.8600, 0.0000, -0.0900, 9.8100, 0.0000, -0.0900, 9.8100, 0.4700, -1.2800, 9.8700, -0.3000, -1.4700, 9.8900, 0.0100, -1.0100, 10.0300, 0.4000, -0.3100, 9.3500, 1.4400, -1.5900, 10.1700, 3.4200, -3.8200, 9.3300, 3.4200, -3.8200, 9.3300, 3.1300, -6.0200, 9.7800, 2.7100, -5.0600, 9.9900, 2.6100, -4.3400, 9.5700, 2.8000, -2.4700, 10.1500, 2.1400, -1.5300, 10.0500, 2.1000, -0.7400, 10.1800, 2.1000, -0.7400, 10.1800, 2.2400, -0.9800, 10.0100, 1.4600, -0.8800, 9.5800, 1.1500, 0.6100, 9.9500, 0.2300, 2.2000, 9.9000, -1.6100, 3.3300, 10.1100, -1.6100, 3.3300, 10.1100, -2.0800, 4.9400, 9.4500, -2.5800, 6.0800, 9.6200, -3.5000, 4.8000, 9.5500, -3.4500, 1.6200, 9.9600, -1.4000, 1.1200, 9.3100, 0.0100, 0.4700, 10.1500, 0.0100, 0.4700, 10.1500, 0.8300, 0.7500, 9.8500, 0.4000, 2.8100, 10.0700, 1.2100, 1.7800, 9.6500, 1.5000, 0.7100, 10.0000, 0.8300, 1.3800, 9.9000, 0.4700, 1.3400, 9.7300, 0.4700, 1.3400, 9.7300, 1.0200, 1.4500, 9.9100, 0.4200, 0.5000, 10.0600, -0.0500, -0.7300, 9.6900, 0.1500, -1.0500, 9.6400, 1.0700, -1.8400, 10.1000, 1.1500, -2.8100, 9.7100, 1.1500, -2.8100, 9.7100, 0.3500, -3.4200, 9.9100
return 0;
void setup() {
Serial.begin(115200);
void loop() {
// the features are stored into flash, and we don't want to load everything into RAM
signal_t features_signal;
// invoke the impulse
EI_IMPULSE_ERROR res = run_classifier(&features_signal, &result, true);
Serial.print("run_classifier returned: ");
Serial.println(res);
if (res != 0) return;
Serial.print("Predictions (DSP: ");
Serial.print(result.timing.dsp);
Serial.print(" ms., Classification: ");
Serial.print(result.timing.classification);
Serial.print(" ms., Anomaly: ");
Serial.print(result.timing.anomaly);
Serial.println(" ms.): ");
// print the predictions
Serial.print("[");
Serial.print(result.classification[ix].value, 5);
Serial.print(", ");
#else
Serial.print(", ");
#endif
Serial.print(result.anomaly, 3);
#endif
Serial.println("]");
delay(1000);
$ arduino-cli compile --fqbn arduino:mbed:nano33ble --build-properties build.extra_flags="-I./src/ -I./src/edge-impulse-sdk/anomaly -I./src/model-parameters -I./src/edge-impulse-sdk -I./src/edge-impulse-sdk/porting -I./src/edge-impulse-sdk/classifier -I./src/edge-impulse-sdk/third_party -I./src/edge-impulse-sdk/third_party/flatbuffers/include -I./src/tflite-model -I./src/edge-impulse-sdk/utensor -I./src/edge-impulse-sdk/CMSIS-DSP/Include -I./src/edge-impulse-sdk/third_party/gemmlowp -DARDUINOSTL_M_H -DMBED_HEAP_STATS_ENABLED=1 -DMBED_STACK_STATS_ENABLED=1 -Og -DMBED_DEBUG -g3" .
$ arduino-cli upload -p $(arduino-cli board list | grep Arduino | cut -d '
