Announcing Support for the Arduino Nicla Voice
Today we are excited to announce official support for the Arduino Nicla Voice development board, the latest of Arduino Pro’s industrial-grade and high-performance platforms, and the second supported by Edge Impulse in the Nicla range.
This is a companion discussion topic for the original entry at https://www.edgeimpulse.com/blog/announcing-support-for-the-arduino-nicla-voice
I’m trying to deploy a model to a Nicla Voice board, but I don’t see it as a target (from the Nicla family only Vision is listed). When should we expect Voice to be available?
Hi @zugaldia
You may be trying to deploy a camera based model? The options you see will be the ones with compatible sensors.
@zugaldia @Eoin Edge Impulse supports Arduino Nicla Voice.
Hi Eoin,
I’m trying to deploy a microphone based model and I have exactly the same problem.
Do you have an idea?
Best regards,
Maxime
@maxime.charriere can you please share the project ID so we can see what the configuration is for your project. Thanks!
The project ID is : 205759
Thanks and BR,
Maxime
Hello @maxime.charriere,
The nicla voice is based on Syntiant.
You’ll need to use a syntiant compatible dsp block. See: Responding to your voice - Syntiant - RC Commands - Edge Impulse Documentation
