Announcing Official Support for the Espressif ESP-EYE (ESP32)
We are thrilled to announce the official support for the Espressif Systems ESP32 system-on-chip (SoC) and the ESP32-based ESP-EYE development board.
This is a companion discussion topic for the original entry at https://www.edgeimpulse.com/blog/announcing-official-support-for-the-espressif-esp-eye-esp32
Would love to see projects on ESP32-S3 based boards running! (with esp-nn optimisations)!
FOMO model mentioned in this article should definitely run around 100ms per inference!
Indeed! I’d be curious to see S3 vs base ESP32 performance when using Edge Impulse.
@mathijs
Are Edge Impulse exported projects already able to take advantage of S3’s SIMD instruction sets/NN optimizations? Do you have any results?
Great - I tried it out with an existing project Goodwatch - Voice controlled alarm clock that resulted in half of the classificaiton time.
"Old:" Predictions (DSP: 87 ms., Classification: 21 ms., Anomaly: 0 ms.):
"ESP-NN:" Predictions (DSP: 77 ms., Classification: 11 ms., Anomaly: 0 ms.):
I am using Platformio and Arduino as a component - to get this working with the new EI firmware I needed to do:
  • replace edge-impulse-sdk with the new firmware.
  • add esp-nn (espressif) to my project
  • fix missing path in conv.cc and fully_connected.cc by adding “edge-impulse-sdk/”
  • Enable ESP-NN via sdkconfig.
Source code (maybe good as example) on GitHub
!! Cant wait for next release - to get the DSP part addressed :slight_smile:
