I have already created a module in Arduino by taking some images for fire detection. It works fine, then I have integrated a servo motor to the code and it is still work fine. Then I have added a compass QM58831 and now in serial monitor it says no object detected for 2 times and then it says failed to capture images. I was thinking if this is because of the initiazltions timing, but do not know how to solve it. The code of the setup void and the compass is provided. Please note that I do not want to use FOMO code format. Also, each code alone works perfectly
void setup()
myservo.attach(servoPin);
startTime = millis();
// pinMode(LED, OUTPUT);
Serial.begin(115200);
// comment out the below line to start inference immediately after upload
while (!Serial)
if (ei_camera_init() == false)
else
ei_printf("\nStarting continuous inference in 2 seconds...\n");
unsigned long startMillis = millis();
while (millis() - startMillis < 2000)
// You can add other non-blocking initializations or tasks here
// For example, you can check a condition and break the loop early if needed
// if (someCondition) {
// break;
// Rest of your setup code...
delay (2500);
compass.init();
void com() {
unsigned long currentMillis = millis();
// Replace delay(200) with millis() for 200ms delay
if (currentMillis - previousMillis200 >= interval200)
int x_value, y_value, z_value, azimuth, bearing;
char direction[strlen("NNE") + 1];
char buffer[strlen("X=-99999 | Y=-99999 | Z=-99999 | A=259° | B=15 | D=NNE") + 1];
compass.read();
x_value = compass.getX();
y_value = compass.getY();
z_value = compass.getZ();
azimuth = compass.getAzimuth();
bearing = compass.getBearing(azimuth);
compass.getDirection(direction, azimuth);
direction[3] = '\0';
sprintf(buffer,
"X=%6d | Y=%6d | Z=%6d | A=%3d° | B=%02hu | %s",
x_value,
y_value,
z_value,
azimuth,
bearing,
direction);
Serial.println(buffer);
previousMillis200 = currentMillis;
Then I am calling com(); in void loop along with fire codes.
