Question/Issue: I have created a basic model that classifies two objects. I want to upload this to my Nicla Vision. Please note that I am new to Arduino’s and Edge Impulse, so I may be missing something obvious here. I have concluded that I am best to use Arduino Library build as I would like to send my results to an IoT dashboard, so I will need to edit the code in the sketch. I have built Arduino Library Deployment. I then followed the steps in the Arduino IDE "Sketch, Include Library, add .Zip library’. I was able to do this successfully. Then I went to 'File, Examples ‘the name of my Edge Impulse project’. I was assuming here would be a sketch of the model I have made, but all I see is example sketches for the nicla sense, nicla vision, portenta h7 etc. The steps online show for the one listed ‘static buffer’ (Arduino library - Edge Impulse Documentation), however this looks like another example?
Can anyone provide me clarity on the situation, please?
I have been using this successfully, but now I have tried to create an anomaly detection using the accelerometer on the board. I created the model, and then Build the Arduino Library. However, when I import the library, there is only the camera, fusion, microphone and microphone continious options. Is this model I trained supposed to be in one of these?
Just select the sensor fusion one. After the run_impulse function, there is a condition to also print the anomaly score if you have one anomaly detection block in your project.
