I am trying to deploy a model with an arduino Nano 33 BLE Sense, and the example using the build in accelerometer works. Also the binary deployed version for the board works.
But I tried to alter the example script in such a way that all the info of my 3 extra IMUs (acc, gyro and orientation) (using a muliplexer) is also working in the “deployed” script.
I was able to gather all the 33 axis data, but my version of the example script seems to have a bug, it would be greatly appreciated if someone can look into this and give me some pointers! In all honesty: altough the example is well documented, I do not exactly know how the library handles all the data.
//altered from:
* Copyright (c) 2020 EdgeImpulse Inc.
* SOFTWARE.
// Includes ----------------------------------------------------------------
#include <adice-project-33-axis_v2_inference.h>
#include <Arduino_LSM9DS1.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BNO055.h>
#include <utility/imumaths.h>
// Constant defines --------------------------------------------------------
#define CONVERT_degperS_TO_radperS 0.01745329252f
Adafruit_BNO055 bno = Adafruit_BNO055(55);
#define TCAADDR 0x70
// Private variables -------------------------------------------------------
static bool debug_nn = true; // Set this to true to see e.g. features generated from the raw signal
const uint8_t TCA_ports[] = {1,2,5}; // define TCA ports that are used
// Ports 4 and 6 seemingly don't work
const uint8_t number_of_IMUs = 3; // define how many IMU's are used
void tcaselect(uint8_t i) {
if (i > 7) return;
Wire.beginTransmission(TCAADDR);
Wire.write(1 << i);
Wire.endTransmission();
// Arduino setup function
void setup()
Serial.begin(115200);
if (!IMU.begin()) {
ei_printf("Failed to initialize IMU on Arduino Nano 33 BLE Sense!\r\n");
else {
ei_printf("IMU on Arduino Nano 33 BLE Sense initialized\r\n");
if (EI_CLASSIFIER_RAW_SAMPLES_PER_FRAME != 33) {
ei_printf("ERR: EI_CLASSIFIER_RAW_SAMPLES_PER_FRAME should be equal to 33 (the 33 sensor axes)\n");
return;
for(uint8_t i=0; i<=number_of_IMUs-1; i++) {
tcaselect(TCA_ports[i]);
Serial.begin(9600);
// Initialise the sensor
bno.begin();
if(!bno.begin())
// There was a problem detecting the BNO055 ... check your connections
Serial.print("IMU ");Serial.print(i+1);Serial.print(" not detected... Check wiring or I2C ADDR!");
while(1);
bno.setExtCrystalUse(true);
* @brief Printf function uses vsnprintf and output using Arduino Serial
* @param[in] format Variable argument list
// Here, the ei_printf function of edge impulse is defined
va_list args;
va_start(args, format);
va_end(args);
if (r > 0) {
Serial.write(print_buf);
* @brief Get data and run inferencing
* @param[in] debug Get debug info if true
void loop()
ei_printf("\nStarting inferencing in 2 seconds...\n");
delay(2000);
ei_printf("Sampling...\n");
for (size_t ix = 0; ix < EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE; ix += 33) { //unsure about the 33 here
// Reading Nano on-board IMU accelerometer
IMU.readAcceleration(buffer[ix], buffer[ix + 1], buffer[ix + 2]);
// Converting to m/s^2
buffer[ix + 1] *= CONVERT_G_TO_MS2;
buffer[ix + 2] *= CONVERT_G_TO_MS2;
// Reading Nano on-board IMU gyroscope
IMU.readGyroscope(buffer[ix + 3], buffer[ix + 4], buffer[ix + 5]);
// Converting to rad/s
buffer[ix + 3] *= CONVERT_degperS_TO_radperS;
buffer[ix + 4] *= CONVERT_degperS_TO_radperS;
buffer[ix + 5] *= CONVERT_degperS_TO_radperS;
//read other IMUS
sensors_event_t event;
// Switching between TCA ports to read out each sensor
// Reading orientation data from sensor and append in buffer
bno.getEvent(&event);
buffer[ix + 9*i + 6] = event.orientation.x;
buffer[ix + 9*i + 7] = event.orientation.y;
buffer[ix + 9*i + 8] = event.orientation.z;
// Reading accelerometer data from sensor and append in buffer
imu::Vector<3> acceleration = bno.getVector(Adafruit_BNO055::VECTOR_ACCELEROMETER);
buffer[ix + 9*i + 9] = acceleration.x();
buffer[ix + 9*i + 10] =acceleration.y();
buffer[ix + 9*i + 11] =acceleration.z();
imu::Vector<3> ang_velocity = bno.getVector(Adafruit_BNO055::VECTOR_GYROSCOPE);
buffer[ix + 9*i + 12] =ang_velocity.x();
buffer[ix + 9*i + 13] =ang_velocity.y();
buffer[ix + 9*i + 14] =ang_velocity.z();
// Wait before taking next sample
signal_t signal;
// Check if buffer has correct dimensions and is classifiable
if (err != 0) {
return;
// Run the classifier
if (err != EI_IMPULSE_OK) {
return;
// print the predictions
result.timing.dsp, result.timing.classification, result.timing.anomaly); // print clasification and anomaly rating
ei_printf(" %s: %.5f\n", result.classification[ix].label, result.classification[ix].value); // print
// Anomaly detection
#endif
#endif
When I try to compile the script it takes about 10 min, and it does compile correctly and is able to upload to the board, but from that moment onwards the serial monitor within Arduino cannot be opened. If the serial window is opened whilst resetting the board it only gives:
Greetings,
Rick
