AI Labelling - 2 step method not functioning?
I am looking to use AI labelling of images of wheelie bins using a two step process to a) identify the wheelie bin (0.1) IoU 0.2 and then b) assign the colour of the bin. The process uses OWL followed by bounding box relabelling with GPT-4o.
OWL labels as “wheelie bin” and GPT-4o assigns colour and prefixes it to wheelie bin. However, when I run the label preview data only one of 6 images is labelled by colour (all the rest are simply labelled wheelie bin).
Can anyone advise if I should be expecting all bins to have a colour assigned (I thought I should be but quite new to using AI labelling)? I want to be sure I get this right before spending more credits on the whole data set.
[Provide the project ID]
A Eye-project-1
Hi @EddyF
Can you share the prompts you used? You can add more weight to the prompt you want to take precedence e.g. (colour :1.0) see AI labeling | Edge Impulse Documentation
