I am trying to add an analog mic to my Pi for a sound recognition project in Edge impulse. I see there is an “On Board Mic” but the pico does not have one. I looked into the PDM.cpp code as well as another forum post on here. It seems I could edit this to run a PDM mic pretty easily. However, I don’t currently have one. Can anyone point me in the right direction to get edge impulse to recognize an analog or I2s Mic. Or am I better off just ordering an PDM mic?
Hello @BJOHN159,
In theory, you just need to have a signal (raw features) and a label to train your embedded machine learning model.
That being said, I never tried our audio pre-processing method with analog microphones (maybe just normalizing the axis would do the trick if your signal is not saturated).
You can try to use the dataforwarder to upload a couple of minutes of audio, then train a first version of your model and see if it gives good results.
Let me know I’m interested to know if you get good results.
Also ping @AlexE, he probably knows more than me about this
See my modified code here ml_audio_classifier_example_for_pico/usb_microphone_analog.c at main · ferrygun/ml_audio_classifier_example_for_pico · GitHub. I am using Max9814 with Pico.
This is based on GitHub - ArmDeveloperEcosystem/microphone-library-for-pico: Capture audio from a microphone on your Raspberry Pi Pico or any RP2040 based board. 🎤
I am using that library too with my analog microphones. It works like charm.
No concerns using analog, should work just fine! The DSP block doesn’t care about scaling (we actually scale everything to ±1 internally for the audio blocks anyway)
