Hello, I have C++ micro speech project generated. I want to deploy it to esp32 with external microphone INMP441. I’m using platformio for my project.
Here is my platformio.ini file:
[env:nodemcu-32s]
platform = espressif32
board = nodemcu-32s
framework = arduinolib_deps =
edge-impulse-sdk
model-parameters
tflite-modelmonitor_speed = 115200
upload_port = COM[6]
And here is my project architect
|–include
|–lib
| |–edge-impulse-sdk
| |–model-parameters
| |–tflite-model
|-- src
|–platformio.ini
When build prject, I receive warning that edge-impulse-sdk cannot found:
Verbose mode can be enabled via
-v, --verboseoption
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/nodemcu-32s.html
PLATFORM: Espressif 32 (3.5.0) > NodeMCU-32S
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (esp-prog) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30100.210531 (3.1.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Library Manager: Installing edge-impulse-sdk
Warning! Could not find the package with ‘edge-impulse-sdk’ requirements for your system ‘windows_amd64’
Found 30 compatible libraries
Scanning dependencies…
Dependency Graph
Building in release mode
Compiling .pio\build\nodemcu-32s\src\main.cpp.o
Generating partitions .pio\build\nodemcu-32s\partitions.bin
Compiling .pio\build\nodemcu-32s\lib2fe\tflite-model\trained_model_compiled.cpp.o
Archiving .pio\build\nodemcu-32s\libFrameworkArduinoVariant.a
Indexing .pio\build\nodemcu-32s\libFrameworkArduinoVariant.a
Compiling .pio\build\nodemcu-32s\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\nodemcu-32s\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\nodemcu-32s\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\nodemcu-32s\FrameworkArduino\IPAddress.cpp.o
lib\tflite-model\trained_model_compiled.cpp:26:64: fatal error: edge-impulse-sdk/tensorflow/lite/c/builtin_op_data.h: No such file or directory
Compiling .pio\build\nodemcu-32s\FrameworkArduino\IPv6Address.cpp.o
compilation terminated.
Compiling .pio\build\nodemcu-32s\FrameworkArduino\MD5Builder.cpp.o
*** [.pio\build\nodemcu-32s\lib2fe\tflite-model\trained_model_compiled.cpp.o] Error 1
I don’t know where is the problem, please help me. Thanks in advance
