Accidentally closed the log window
I accidentally closed the log window which is present in the right side when doing “Model testing” and cannot get it back.
Is there a way to get it back?
@SVMJ can you just click Classify selected again? The DSP output is cached so should run pretty fast.
Hey @janjongboom I was trying out things and couldn’t make that thing work due to some issue. I created a new project with same settings and everything works fine now!
@SVMJ Great, if you run into this again, please let us know the project ID here and we’ll see if we can find the root cause!
