I am now working on simplifying data collection for my students for the accelerometer and microphone, which are a bit tricky as they have a time duration.
The Accelerometer does not seem too bad, in the EdgeImpulse Arduino Library examples. It looks fairly easy, using a buffer to sequence the incoming data. I might change it around a bit using an array which my students are more familiar with. (At this point understanding is more important than speed)
Basic Acceleration Algorithm:
- grab x,y,z samples, convert to accelerations (*9.8)
- wait correct number of milliseconds
- repeat until correct number of samples
- convert samples to a numpy array for classification
IMU.readAcceleration(buffer[ix], buffer[ix + 1], buffer[ix + 2]);
buffer[ix + 1] *= CONVERT_G_TO_MS2;
buffer[ix + 2] *= CONVERT_G_TO_MS2;
signal_t signal;
if (err != 0) {
return;
The concern comes with the audio samples which the EdgeImpulse Arduino Library examples are quiet complex using several functions to organize the more complex audio information.
Does anyone have a basic algorithm for what is happening with the audio samples?
In the PDMSerialPlotter it doesn’t seem too confusing
This example reads audio data from the on-board PDM microphones, and prints
out the samples to the Serial console. The Serial Plotter built into the
Arduino IDE can be used to plot the audio data (Tools -> Serial Plotter)
Circuit:
- Arduino Nano 33 BLE board
This example code is in the public domain.
#include <PDM.h>
// buffer to read samples into, each sample is 16-bits
short sampleBuffer[256];
// number of samples read
volatile int samplesRead;
void setup() {
Serial.begin(9600);
while (!Serial);
// configure the data receive callback
PDM.onReceive(onPDMdata);
// optionally set the gain, defaults to 20
// PDM.setGain(30);
// initialize PDM with:
// - one channel (mono mode)
// - a 16 kHz sample rate
if (!PDM.begin(1, 16000)) {
Serial.println("Failed to start PDM!");
while (1);
void loop() {
// wait for samples to be read
if (samplesRead) {
// print samples to the serial monitor or plotter
for (int i = 0; i < samplesRead; i++) {
Serial.println(sampleBuffer[i]);
// clear the read count
samplesRead = 0;
void onPDMdata() {
// query the number of bytes available
int bytesAvailable = PDM.available();
// read into the sample buffer
PDM.read(sampleBuffer, bytesAvailable);
// 16-bit, 2 bytes per sample
samplesRead = bytesAvailable / 2;
but when I look at the EdgeImpulse Arduino microphone Library I get lost
* Copyright (c) 2020 EdgeImpulse Inc.
* SOFTWARE.
// If your target is limited in memory remove this macro to save 10K RAM
#define EIDSP_QUANTIZE_FILTERBANK 0
#include <PDM.h>
#include <words_inference.h>
/** Audio buffers, pointers and selectors */
typedef struct {
int16_t *buffer;
uint8_t buf_ready;
uint32_t buf_count;
uint32_t n_samples;
} inference_t;
static inference_t inference;
static signed short sampleBuffer[2048];
void setup()
Serial.begin(115200);
ei_printf("\tInterval: %.2f ms.\n", (float)EI_CLASSIFIER_INTERVAL_MS);
ei_printf("\tSample length: %d ms.\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT / 16);
if (microphone_inference_start(EI_CLASSIFIER_RAW_SAMPLE_COUNT) == false) {
ei_printf("ERR: Failed to setup audio sampling\r\n");
return;
* @brief Arduino main function. Runs the inferencing loop.
void loop()
ei_printf("Starting inferencing in 2 seconds...\n");
delay(2000);
ei_printf("Recording...\n");
if (!m) {
return;
ei_printf("Recording done\n");
signal_t signal;
signal.total_length = EI_CLASSIFIER_RAW_SAMPLE_COUNT;
signal.get_data = µphone_audio_signal_get_data;
EI_IMPULSE_ERROR r = run_classifier(&signal, &result, debug_nn);
if (r != EI_IMPULSE_OK) {
return;
// print the predictions
ei_printf("Predictions ");
ei_printf(": \n");
#endif
* @brief Printf function uses vsnprintf and output using Arduino Serial
* @param[in] format Variable argument list
va_list args;
va_start(args, format);
va_end(args);
if (r > 0) {
Serial.write(print_buf);
* @brief PDM buffer full callback
* Get data and call audio thread callback
static void pdm_data_ready_inference_callback(void)
int bytesRead = PDM.read((char *)&sampleBuffer[0], bytesAvailable);
if (inference.buf_ready == 0) {
for(int i = 0; i < bytesRead>>1; i++) {
inference.buffer[inference.buf_count++] = sampleBuffer[i];
if(inference.buf_count >= inference.n_samples) {
inference.buf_count = 0;
inference.buf_ready = 1;
break;
* @brief Init inferencing struct and setup/start PDM
* @param[in] n_samples The n samples
* @return { description_of_the_return_value }
inference.buffer = (int16_t *)malloc(n_samples * sizeof(int16_t));
if(inference.buffer == NULL) {
return false;
inference.n_samples = n_samples;
inference.buf_ready = 0;
PDM.onReceive(&pdm_data_ready_inference_callback);
PDM.setGain(80);
PDM.setBufferSize(4096);
if (!PDM.begin(1, EI_CLASSIFIER_FREQUENCY)) {
ei_printf("Failed to start PDM!");
microphone_inference_end();
return false;
return true;
* @brief Wait on new data
* @return True when finished
while(inference.buf_ready == 0) {
delay(10);
return true;
* Get raw audio signal data
numpy::int16_to_float(&inference.buffer[offset], out_ptr, length);
return 0;
* @brief Stop PDM and release buffers
static void microphone_inference_end(void)
PDM.end();
free(inference.buffer);
#if !defined(EI_CLASSIFIER_SENSOR) || EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_MICROPHONE
#error "Invalid model for current sensor."
#endif
Anyone want to make a stab at the steps for a basic sound recording algorithm going on here?
