I’ve been working through using the ingestion API today using Python with some success, until I examine an uploaded wav file in studio. The wav file itself looks correct when I print the wav_file content to the console, but it ends up as a 0 second sample in studio.
Here is my full source…I must be missing something simple…?
import json
import time
import hmac
import hashlib
import requests
from scipy.io import wavfile
HMAC_KEY = "..."
API_KEY = "..."
samplerate, wav_data = wavfile.read('final.wav')
wav_data = wav_data.tolist()
emptySignature = ''.join(['0'] * 64)
data = {
"protected": {
"ver": "v1",
"alg": "HS256",
"iat": time.time()
"signature": emptySignature,
"payload": {
"device_name": "DC:A6:32:BC:0A:00",
"device_type": "RASPBERRY_PI",
"interval_ms": 1000 / samplerate,
"sensors": [{"name": "audio", "units": "wav"}],
"values": [wav_data]
# encode in JSON
encoded = json.dumps(data)
# sign message
signature = hmac.new(bytes(HMAC_KEY, 'utf-8'),
msg=encoded.encode('utf-8'), digestmod=hashlib.sha256).hexdigest()
# set the signature again in the message, and encode again
data['signature'] = signature
# and upload the file
res = requests.post(url='https://ingestion.edgeimpulse.com/api/training/data',
data=encoded,
headers={
'Content-Type': 'application/json',
'x-file-name': 'major_failure',
'x-label': 'major failure',
'x-api-key': API_KEY
if (res.status_code == 200):
print('Uploaded file to Edge Impulse', res.status_code, res.content)
else:
print('Failed to upload file to Edge Impulse', res.status_code, res.content)
