Hello,
I’m trying to deploy two projects on the same microcontroller. First of all, is it possible to deploy them as C++ libraries using the mbedOS IDE?
The idea is to design two neural networks that require the same number of features (thus, the Impulse design, Time Series data, and Processing Block are the same), but with different learning blocks. The microcontroller should acquire a signal, process it with the two different NNs, and produce two different results. It’s not important for the microcontroller to perform both inferences simultaneously.
Is it possible to achieve this? How?
Thank you for any assistance you can provide.
