I encountered error when connecting Rasberry PI 4 tp Edge Impluse.
Installation Dependencies version of node.js is blocking my ability to add new device.
node.js fails to install because library libstdc++.so.6 is out of date.
node-v
node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26’ not found (required by node)
RPI 4 running NAVIO2 SD image with Real Time extensions.
strings /usr/lib/arm-linux-gnueabihf/libstdc++.so.6 | grep GLIBC
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_3.4.14
GLIBCXX_3.4.15
GLIBCXX_3.4.16
GLIBCXX_3.4.17
GLIBCXX_3.4.18
GLIBCXX_3.4.19
GLIBCXX_3.4.20
GLIBCXX_3.4.21
GLIBCXX_3.4.22
GLIBCXX_3.4.23
GLIBCXX_3.4.24
GLIBCXX_3.4.25
GLIBC_2.4
GLIBC_2.18
GLIBC_2.16
GLIBC_2.17
GLIBCXX_DEBUG_MESSAGE_LENGTH
I’m trying to add a RPI 4 which is running a vendor provided image. The NAVIO2 SD card image does not have the perquisite version of libstdc++so.6. Is their a reason you need a specific version of node.js. NAVIO2 requires real time extension to operate onboard GPS UBLOK .
Can you support a older version of node.js? NAVIO only support GLIBXX.3.4.25 and node.js requires GLIBXX.3.4.26.
Can you et me out of this Ubunta update nightmare?
