Cheers Jan! This is exactly what I have done, SOX is really a good and simple way of doing this …
Now I have moved on, and have done the NN stage too, I can download the bin to the board via the command line, namely with the edge-impulse-flash… and it works, however, I would like to move on…
Therefore, I am wondering how to bring that C code to the Segger IDE, any ideas?
I guess there are instructions that could be followed? In addition, I guess this should be done with the “edge-impulse-standalone.emProject” and e.g. the Segger IDE, but somehow I cannot compile the “edge-impulse-standalone.emProject” got an error, see below:
Building 'edge-impulse-standalone' from solution 'edge-impulse-standalone' in configuration 'Debug'
1> build/bin/FreeRTOS_CLI.o does not exist.
1> Compiling 'FreeRTOS_CLI.c'
1> /opt/gcc-arm-none-eabi-8-2018-q4-major/bin/arm-none-eabi-gcc -c -mthumb -fno-exceptions -Wno-unused-variable -nostartfiles -Wno-unused-parameter -Wno-parentheses -Wno-unused-function -ggdb -fno-common -fmessage-length=0 -std=gnu99 -DSRAM -DPROJ_NAME=edge-impulse-standalone -DECM3532 -I../../Thirdparty/edge_impulse -I../../Thirdparty/edge_impulse/edge-impulse-sdk/CMSIS/DSP/Include -I../../Thirdparty/edge_impulse/edge-impulse-sdk/CMSIS/Core/Include -I../../Platform/ECM3532/M3/hw/hal/common/include -I../../Platform/ECM3532/Common/framework/inc -I../../eta_ai_bsp/inc -Isrc -I../../Platform/ECM3532/M3/framework/executor/include/pub -I../../Platform/ECM3532/M3/NN_kernels/include -I. -I../../Platform/ECM3532/M3 -I../../Platform/ECM3532/M3/util/include -I../../Platform/ECM3532/M3/hw/include -I../../Platform/ECM3532/M3/hw/include/ecm3532 -I../../Platform/ECM3532/M3/hw/board/ecm3532/ai_vision/include -I../../Platform/ECM3532/M3/util/console/include -I../../Platform/ECM3532/M3/util/dsp_helper/include -Iinclude -I../../Platform/ECM3532/M3/hw/csp/ecm3532/common/csp/inc -I../../Platform/ECM3532/M3/hw/csp/ecm3532/m3/reg/inc -I../../Platform/ECM3532/M3/hw/csp/common/inc -I../../Platform/ECM3532/M3/hw/csp/ecm3532/m3/csp/inc -I../../Thirdparty/FreeRTOS/Source/include -I../../Thirdparty/FreeRTOS/Source/portable/GCC/ARM_CM3 -I../../Thirdparty/FreeRTOS-Plus/Source/FreeRTOS-Plus-CLI -I../../Platform/ECM3532/M3/hw/hal/common/include -I../../Platform/ECM3532/M3/hw/hal/ecm3532/include -I../../Platform/ECM3532/M3/hw/drivers/spi_flash/common -I../../Platform/ECM3532/M3/hw/drivers/spi_flash/maxim -I../../Platform/ECM3532/M3/framework/rpc/src -I../../Platform/ECM3532/M3/framework/rpc/include -I../../Platform/ECM3532/Common/framework/inc -I../../Platform/ECM3532/M3/hw/ipc/common/include ../../Thirdparty/FreeRTOS-Plus/Source/FreeRTOS-Plus-CLI/FreeRTOS_CLI.c -MD -MF build/bin/FreeRTOS_CLI.d -fno-diagnostics-show-caret -o build/bin/FreeRTOS_CLI.o -O3 -g -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mfpu=vfp -mfloat-abi=soft -mlittle-endian
2> build/bin/croutine.o does not exist.
2> Compiling 'croutine.c'
2> /opt/gcc-arm-none-eabi-8-2018-q4-major/bin/arm-none-eabi-gcc -c -mthumb -fno-exceptions -Wno-unused-variable -nostartfiles -Wno-unused-parameter -Wno-parentheses -Wno-unused-function -ggdb -fno-common -fmessage-length=0 -std=gnu99 -DSRAM -DPROJ_NAME=edge-impulse-standalone -DECM3532 -I../../Thirdparty/edge_impulse -I../../Thirdparty/edge_impulse/edge-impulse-sdk/CMSIS/DSP/Include -I../../Thirdparty/edge_impulse/edge-impulse-sdk/CMSIS/Core/Include -I../../Platform/ECM3532/M3/hw/hal/common/include -I../../Platform/ECM3532/Common/framework/inc -I../../eta_ai_bsp/inc -Isrc -I../../Platform/ECM3532/M3/framework/executor/include/pub -I../../Platform/ECM3532/M3/NN_kernels/include -I. -I../../Platform/ECM3532/M3 -I../../Platform/ECM3532/M3/util/include -I../../Platform/ECM3532/M3/hw/include -I../../Platform/ECM3532/M3/hw/include/ecm3532 -I../../Platform/ECM3532/M3/hw/board/ecm3532/ai_vision/include -I../../Platform/ECM3532/M3/util/console/include -I../../Platform/ECM3532/M3/util/dsp_helper/include -Iinclude -I../../Platform/ECM3532/M3/hw/csp/ecm3532/common/csp/inc -I../../Platform/ECM3532/M3/hw/csp/ecm3532/m3/reg/inc -I../../Platform/ECM3532/M3/hw/csp/comlibrarymon/inc -I../../Platform/ECM3532/M3/hw/csp/ecm3532/m3/csp/inc -I../../Thirdparty/FreeRTOS/Source/include -I../../Thirdparty/FreeRTOS/Source/portable/GCC/ARM_CM3 -I../../Thirdparty/FreeRTOS-Plus/Source/FreeRTOS-Plus-CLI -I../../Platform/ECM3532/M3/hw/hal/common/include -I../../Platform/ECM3532/M3/hw/hal/ecm3532/include -I../../Platform/ECM3532/M3/hw/drivers/spi_flash/common -I../../Platform/ECM3532/M3/hw/drivers/spi_flash/maxim -I../../Platform/ECM3532/M3/framework/rpc/src -I../../Platform/ECM3532/M3/framework/rpc/include -I../../Platform/ECM3532/Common/framework/inc -I../../Platform/ECM3532/M3/hw/ipc/common/include ../../Thirdparty/FreeRTOS/Source/croutine.c -MD -MF build/bin/croutine.d -fno-diagnostics-show-caret -o build/bin/croutine.o -O3 -g -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mfpu=vfp -mfloat-abi=soft -mlittle-endian
3> build/bin/list.o does not exist.
2> In file included from ../../Thirdparty/FreeRTOS/Source/include/FreeRTOS.h:56,
2> from ../../Thirdparty/FreeRTOS/Source/croutine.c:28:
2> ../../Thirdparty/FreeRTOS/Source/include/FreeRTOSConfig.h:30:10: fatal error: config.h: No such file or directory
2> compilation terminated.
3> Compiling 'list.c'
3> /opt/gcc-arm-none-eabi-8-2018-q4-major/bin/arm-none-eabi-gcc -c -mthumb -fno-exceptions -Wno-unused-variable -nostartfiles -Wno-unused-parameter -Wno-parentheses -Wno-unused-function -ggdb -fno-common -fmessage-length=0 -std=gnu99 -DSRAM -DPROJ_NAME=edge-impulse-standalone -DECM3532 -I../../Thirdparty/edge_impulse -I../../Thirdparty/edge_impulse/edge-impulse-sdk/CMSIS/DSP/Include -I../../Thirdparty/edge_impulse/edge-impulse-sdk/CMSIS/Core/Include -I../../Platform/ECM3532/M3/hw/hal/common/include -I../../Platform/ECM3532/Common/framework/inc -I../../eta_ai_bsp/inc -Isrc -I../../Platform/ECM3532/M3/framework/executor/include/pub -I../../Platform/ECM3532/M3/NN_kernels/include -I. -I../../Platform/ECM3532/M3 -I../../Platform/ECM3532/M3/util/include -I../../Platform/ECM3532/M3/hw/include -I../../Platform/ECM3532/M3/hw/include/ecm3532 -I../../Platform/ECM3532/M3/hw/board/ecm3532/ai_vision/include -I../../Platform/ECM3532/M3/util/console/include -I../../Platform/ECM3532/M3/util/dsp_helper/include -Iinclude -I../../Platform/ECM3532/M3/hw/csp/ecm3532/common/csp/inc -I../../Platform/ECM3532/M3/hw/csp/ecm3532/m3/reg/inc -I../../Platform/ECM3532/M3/hw/csp/common/inc -I../../Platform/ECM3532/M3/hw/csp/ecm3532/m3/csp/inc -I../../Thirdparty/FreeRTOS/Source/include -I../../Thirdparty/FreeRTOS/Source/portable/GCC/ARM_CM3 -I../../Thirdparty/FreeRTOS-Plus/Source/FreeRTOS-Plus-CLI -I../../Platform/ECM3532/M3/hw/hal/common/include -I../../Platform/ECM3532/M3/hw/hal/ecm3532/include -I../../Platform/ECM3532/M3/hw/drivers/spi_flash/common -I../../Platform/ECM3532/M3/hw/drivers/spi_flash/maxim -I../../Platform/ECM3532/M3/framework/rpc/src -I../../Platform/ECM3532/M3/framework/rpc/include -I../../Platform/ECM3532/Common/framework/inc -I../../Platform/ECM3532/M3/hw/ipc/common/include ../../Thirdparty/FreeRTOS/Source/list.c -MD -MF build/bin/list.d -fno-diagnostics-show-caret -o build/bin/list.o -O3 -g -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mfpu=vfp -mfloat-abi=soft -mlittle-endian
1> In file included from ../../Thirdparty/FreeRTOS/Source/include/FreeRTOS.h:56,
1> from ../../Thirdparty/FreeRTOS-Plus/Source/FreeRTOS-Plus-CLI/FreeRTOS_CLI.c:33:
1> ../../Thirdparty/FreeRTOS/Source/include/FreeRTOSConfig.h:30:10: fatal error: config.h: No such file or directory
1> compilation terminated.
3> In file included from ../../Thirdparty/FreeRTOS/Source/include/FreeRTOS.h:56,
3> from ../../Thirdparty/FreeRTOS/Source/list.c:30:
3> ../../Thirdparty/FreeRTOS/Source/include/FreeRTOSConfig.h:30:10: fatal error: config.h: No such file or directory
3> compilation terminated.
Build failed
Any ideas how to fix this, if I could actually make use of it? I just want to use the C code from the edge impulse and turn on/off the LEDs on my dev board… I am on linux and working with the eta… sensor board.
Any help is much appreciated!
BR.
PS: sorry for posting this here, probably it should have a different title, I am sure the forum admin will organise it properly…
