In the configuration for Huge app on the ESP32 CAM, max flash is 3145728, max ram is 327680
Is this enough to run the application? The CAM board has a micro SD card slot available as well…
Great Idea!!
When you load the ESP32 board files there is a sample application, CameraWebServer, try that out first to make sure everything works.
Thanks!
Oh, you will also nee a USB to Serial adapter, like the FTDI board. Set the voltage switch to 5v.
See this link: https://randomnerdtutorials.com/program-upload-code-esp32-cam/
Yeah that should be fine - will check if I have the board in!
Hi Any update on the ESP32 CAM?
@tcontrada I have the board laying around but haven’t gotten to use it yet. In the meantime we had a few users that have used the ESP32 CAM, incl. here: ESP32WROOM or ESP8266EX Node MCU Support and I’ve written an example to create a signal from a RGB565 frame buffer (which I think the ESP32 CAM uses): https://github.com/edgeimpulse/example-signal-from-rgb565-frame-buffer
@janjongboom I just received an ESP32 cam. I’m trying to learn how the data is classified. Does the software support classification of live streaming data or is it just classifying single pictures/frames?
Frame-by-frame, I don’t really get how you would do live streaming of the data. The buffer should remain the same until classification is done, then you can read from the camera again.
Good point, I didn’t think of that. I lack that basic understanding on how data is read from the camera and how that data is structured which I’m currently researching.
I also read your github. So I need to convert the RGB565 to RGB888 then I can feed it into the static buffer?
@electronictechgreg Yes, just use the example repo to turn the RGB565 frame buffer into a signal_t structure. You then ask the classifier to classify the signal. Then you get predictions, and you can take the next photo!
I watched your video on Adding sight to your sensors. When I was talking about streaming what I meant was live classification like you did in the video. So that answered that question for me.
As for the ESP32 cam, apparently I can output in RGB888 format using the fmt2rgb888 function from the esp_camera.h library. Then convert it to a signal_t structure then feed it into the classifier. I think I got it.
@janjongboom I apologize if this issue has been resolved and I just could not find a resolution. I uploaded static_buffer sketch to ESP32 Cam board and getting ‘panic’ exception. When I decoded the trace I found this
As per all the suggestion in this thread, I converted feature to RGB888 following your repo. I have tested basic web camera code with this board which is working. So my board and fine. I also uploaded the same sketch to Nano BLE sense and it worked. Just can’t get it working with ESP32 Cam. Here is my code.
/* Edge Impulse Arduino examples
* Copyright (c) 2020 EdgeImpulse Inc.
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to whom the Software is
* furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
* AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
* OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
* SOFTWARE.
/* Includes ---------------------------------------------------------------- */
#include <animal_faces_inference.h>
#define CUTOUT_COLS EI_CLASSIFIER_INPUT_WIDTH
#define CUTOUT_ROWS EI_CLASSIFIER_INPUT_HEIGHT
#define FRAME_BUFFER_COLS 48
#define FRAME_BUFFER_ROWS 48
uint16_t frame_buffer[FRAME_BUFFER_COLS * FRAME_BUFFER_ROWS] = { 0 };
const int cutout_row_start = (FRAME_BUFFER_ROWS - CUTOUT_ROWS) / 2;
const int cutout_col_start = (FRAME_BUFFER_COLS - CUTOUT_COLS) / 2;
static const float features[] = {
0xaf9118, 0xcea714, 0xdbb618, 0xd5b613, 0xcbb10d, 0xd7bc0e, 0xdfc017, 0xdcb924, 0xbea32e, 0xc3af40, 0xcdba5d, 0xc5b467, 0xbcb57c, 0xb4b48f, 0xaaaa81, 0x9ea483, 0x95a491, 0x9db3b4, 0x9eb5bc, 0x96acb0, 0x8f9683, 0x858366, 0x6e6b51, 0x646249, 0x6c6a54, 0x5f5c4b, 0x5c5948, 0x555140, 0x564e3b, 0x655b43, 0x655d43, 0x685e46, 0x6a614a, 0x6b634c, 0x72674d, 0x797052, 0x827756, 0x847a5c, 0x897f63, 0x8c8261, 0x9d9777, 0xa9ada5, 0x9e9f8c, 0x9c9477, 0x9a8f6a, 0x9b8e66, 0x9a8c64, 0x9a8d66, 0xb18e23, 0xd1a320, 0xc6a62b, 0xb09c21, 0xc0a517, 0xd4b80e, 0xceb207, 0xe4c114, 0xe6c01d, 0xdbbc17, 0xdfbf18, 0xdec019, 0xd7b81e, 0xd4b72d, 0xc3a92c, 0xc5a937, 0xb4a143, 0x9d985a, 0x94925d, 0x918a5a, 0x94823a, 0x8f8137, 0x655d36, 0x524e34, 0x524d38, 0x534f3a, 0x545240, 0x444134, 0x464237, 0x4c473a, 0x524c3d, 0x534c3d, 0x595241, 0x5b5542, 0x605844, 0x685e48, 0x71674d, 0x72674f, 0x796d52, 0x7e7255, 0x887d5a, 0x9b9677, 0x928864, 0x8d7f5c, 0x8c7e5d, 0x90835f, 0x968761, 0x93875d, 0xb08d37, 0xa6852f, 0x9a8426, 0x8f7d2c, 0xb89c22, 0xbea216, 0xb0990c, 0xceaf15, 0xe5c01f, 0xd7b70b, 0xdab918, 0xd9b81f, 0xddc017, 0xdabf16, 0xd3b71c, 0xe1c02d, 0xc9ae25, 0xc2a71f, 0xc7a826, 0xbba120, 0xc0a324, 0xaf9625, 0x95812a, 0x8c782c, 0x5d542f, 0x4c4731, 0x554f34, 0x4c4632, 0x4d4935, 0x4a4737, 0x4c4839, 0x4c473b, 0x4f4b3c, 0x544f3f, 0x565140, 0x635c44, 0x6c664b, 0x665e4c, 0x706750, 0x807558, 0x898160, 0x858067, 0x898170, 0x80755e, 0x82765e, 0x84775d, 0x897a5d, 0x8c7a5d, 0xc4a819, 0xceb026, 0xc6aa19, 0xc3a319, 0xcda814, 0xd4b109, 0xcfaf12, 0xbc9d14, 0xc6ac11, 0xbaa50f, 0xcaad0f, 0xd8b50e, 0xdbbc0c, 0xd8bd0c, 0xccb214, 0xd4b718, 0xdabd0f, 0xdbbd10, 0xddbd1e, 0xd6ba18, 0xd7b718, 0xd8b81e, 0xcfb026, 0xd5b02b, 0xc2a224, 0xab9222, 0xa99022, 0xa58b24, 0x998323, 0x927a31, 0x745f36, 0x6e5c39, 0x605537, 0x544d3a, 0x5a553c, 0x5a553e, 0x5f5a41, 0x686347, 0x706951, 0x817958, 0x8c855f, 0x8b8461, 0x847e6b, 0x7c735d, 0x7a6c59, 0x7e6f5b, 0x84725a, 0x897359, 0xc3ac02, 0xd3b50a, 0xcfab14, 0xcfaa0e, 0xd7b60a, 0xd7b711, 0xdbb90c, 0xd4b506, 0xcdb405, 0xb6a403, 0xb8a007, 0xc3a90b, 0xaf9f05, 0xc7b204, 0xcab10f, 0xcaae12, 0xd5ba08, 0xddc009, 0xe2c114, 0xd6b316, 0xdfbd14, 0xe5c123, 0xebc632, 0xe1bd27, 0xdcba21, 0xdeb922, 0xdbb325, 0xd6ae23, 0xcaa323, 0xd3aa30, 0xcba53f, 0xc69e40, 0xc19f40, 0x9f8636, 0x988137, 0x8d793b, 0x6d5f3e, 0x6c6140, 0x766945, 0x7a6d4c, 0x7a6e4c, 0x88825d, 0x7a745e, 0x756a54, 0x766854, 0x796a55, 0x837054, 0x8b7354, 0xc1a702, 0xc8ac04, 0xc7a117, 0xc8992c, 0xc9a115, 0xbc9c11, 0xcdb20a, 0xcdb701, 0xcab504, 0xc5b003, 0xccae09, 0xc8a90b, 0xc3aa0a, 0xd0b604, 0xd9be07, 0xdcbc0e, 0xc8ac0e, 0xc5ad0a, 0xccb60b, 0xc2b00b, 0xcbb609, 0xd2b415, 0xd3b31f, 0xd4b419, 0xd7b51d, 0xd6b328, 0xd7b525, 0xd4b122, 0xd4b129, 0xceae2c, 0xd1af2d, 0xdbb543, 0xd7b448, 0xd3b040, 0xd1ae42, 0xd7b14e, 0xcaa24f, 0xbb9749, 0xa88d45, 0xa38648, 0xae8f4c, 0x958651, 0x817753, 0x74664d, 0x736650, 0x776853, 0x7f6b51, 0x897152, 0xa59009, 0xb99e05, 0xb89313, 0xc9992c, 0xc99e23, 0xc3a014, 0xcfb219, 0xbda70d, 0xc5aa0e, 0xceb114, 0xb9a416, 0xceb214, 0xc29e17, 0xc3ab19, 0xc4ac0f, 0xd2b110, 0xbc981a, 0xa88a1b, 0xb29f0e, 0xbfac0a, 0xb8a706, 0xc7ac07, 0xbaa10b, 0xbfa514, 0xd0b215, 0xc2a612, 0xc0a60e, 0xc5ac13, 0xbca020, 0xaf9525, 0xbe9d1f, 0xc7ac26, 0xceb42f, 0xcdb131, 0xc7ac2f, 0xc7a93a, 0xc9aa41, 0xc6aa42, 0xc6a943, 0xbea143, 0xb89c43, 0xbd9f47, 0xb3974c, 0xad924d, 0xac8f4c, 0xa58a4e, 0xaa8e51, 0xb19153, 0x9f890e, 0xbd990d, 0xb99218, 0xa88827, 0xb89b26, 0xb0932d, 0xbb9727, 0xb39918, 0xa99315, 0xc1a11d, 0x938221, 0xad9524, 0xab9023, 0x816f2c, 0x8f792a, 0xab8f23, 0x9e8624, 0x9f8329, 0xc9b11a, 0xa99a12, 0x8b7a19, 0xa58f11, 0xb7a107, 0xb39712, 0xc5a718, 0xb29917, 0xac9516, 0xa9931c, 0xa2892a, 0x96852b, 0x978429, 0x988a25, 0xa79424, 0xaa952d, 0xa58e38, 0x9b8735, 0x937e38, 0x8f7e38, 0x9d8a3a, 0x9e863b, 0x8c7e3c, 0xa58e41, 0xbb9948, 0xc2a14e, 0xc5a34c, 0xbf9c4a, 0xc1a04d, 0xc6a450, 0xa88e18, 0xc39d15, 0xc8a40c, 0xa8841e, 0xbd9320, 0xb29327, 0xbfa224, 0xbba515, 0xbba613, 0xc9b315, 0xbaa021, 0xb69129, 0x9f8025, 0x967722, 0x977223, 0xc29130, 0x997b2a, 0x6f6025, 0x988824, 0xa6941f, 0x846c27, 0x927429, 0xb48e23, 0xb78f2a, 0xbd942b, 0xb9922e, 0xb18d2d, 0xc29d3c, 0xbf9c3c, 0xa28325, 0x967c30, 0x967f36, 0x997b2c, 0xa58733, 0xa2863f, 0xa7843a, 0xbc923e, 0xb58b40, 0xa2813d, 0x9a7f40, 0x9a8040, 0x947d40, 0x9c8244, 0x9f8645, 0xa28847, 0xab8b49, 0xb68f4b, 0xba974f, 0xa38a1c, 0xa08c11, 0xbfab02, 0xcaaf0a, 0xbfa50f, 0xbba90d, 0xb8ab09, 0x988612, 0xa98c27, 0xc0a52c, 0xb8a41c, 0xc4a918, 0xb69224, 0xba9c0e, 0xcda90f, 0xdba428, 0xd29c33, 0xaf862c, 0xb0872c, 0xca9b2f, 0xc89329, 0xd8a233, 0xd29e32, 0xcd983a, 0xd29d36, 0xcd982e, 0xc39232, 0xc39933, 0xb0922c, 0xac8d22, 0xb6962a, 0xaa892f, 0xa6812b, 0xa7832f, 0xa48130, 0xaf8633, 0xc6953b, 0xb88f40, 0xa0833e, 0x9e8541, 0x998342, 0xa08848, 0xa38946, 0x9e8545, 0xa38748, 0xac8d4c, 0xb38f4d, 0xbb984f, 0xa28219, 0x847911, 0x998e09, 0x989409, 0x938c10, 0xa99612, 0xad9813, 0xbb9e15, 0xc09c2f, 0xbea32e, 0x9c9312, 0xa59906, 0xab9b0c, 0x7c750c, 0xb1a00c, 0xdbbd0f, 0xd1af13, 0xc3a119, 0xc2a415, 0xc3a01c, 0xb1941b, 0xd4a523, 0xca9429, 0xc79733, 0xb79524, 0xb8901d, 0xbc8f24, 0xb68a30, 0xae9124, 0xa08a1a, 0xa89016, 0xb09119, 0xa98629, 0xa38928, 0xa5842f, 0xa07f30, 0xb38b36, 0xb99239, 0xa5843a, 0xaa8e3e, 0xab923f, 0xad8f47, 0xaf8b45, 0xb59047, 0xb5944a, 0xb9964c, 0xb8964a, 0xba9d4d, 0xa3850c, 0xae8e08, 0xbf9f07, 0x9b8808, 0x69680b, 0x83741b, 0x90801f, 0xb2951a, 0xa68826, 0xa29224, 0xa39b13, 0xaca007, 0xbba901, 0x91840e, 0x9f9014, 0xa59a08, 0xb4ad01, 0xb0a503, 0xa89b04, 0xae9e0d, 0xb6a111, 0xbc9c1c, 0xb69023, 0xaa921c, 0x918f0e, 0xae9f08, 0xb49f12, 0xab921f, 0x9e8a19, 0x9f9115, 0x9a8a19, 0xa18f18, 0x837925, 0x8f8625, 0x978428, 0x957d2c, 0x9d7b30, 0xab8833, 0xb08d37, 0xa38b38, 0xa38f3a, 0xac8f39, 0xaa8743, 0xad884a, 0xb08d4a, 0xb9994b, 0xb19a49, 0xaf964e, 0x9b8110, 0x806913, 0x9a8109, 0xb99807, 0x8a7710, 0x88761e, 0x938022, 0x978317, 0xa0901b, 0x827b18, 0x706b13, 0x9f8f0e, 0xab9111, 0xad9e0a, 0xa39d0e, 0x988c18, 0xa8a00b, 0xb0ab06, 0xaa9c06, 0xbb9f17, 0xb9a511, 0x998b0d, 0x9e9011, 0x868112, 0x8c8911, 0x958f08, 0x817914, 0x8d831a, 0x968025, 0x7e7226, 0x7c7322, 0xa4911f, 0x978829, 0x958a2b, 0x8c812b, 0x8c7830, 0x987d30, 0x9e8037, 0x9a7c3b, 0x8b743a, 0x917b42, 0x988146, 0x9b814a, 0x9e8151, 0xa08654, 0xa08a53, 0xa99452, 0xae9456, 0x8c7218, 0x896b1a, 0x907412, 0xa9890a, 0xac8c0f, 0xa38517, 0xa58322, 0x877417, 0x837a11, 0x928a0b, 0x8d7f0f, 0x907f12, 0x9e8215, 0xb49f07, 0xaa9c0c, 0x978616, 0x958311, 0xa59211, 0x9e8412, 0xaf9117, 0xbea20e, 0xa38d08, 0x9f8e09, 0x746c12, 0x726b13, 0x898011, 0x948014, 0x907813, 0x977f20, 0x867127, 0x7c6823, 0x776822, 0x7e6c2a, 0x87782a, 0x87762b, 0x776c32, 0x867637, 0x937e40, 0x83733e, 0x87753f, 0x8f7a42, 0x9c854a, 0x947f4b, 0x917f54, 0x9e895b, 0xa18d60, 0xa79264, 0xaa9767, 0x8b7c0a, 0x988109, 0xa2850d, 0x957e0b, 0xa48e07, 0xa89305, 0xaf9309, 0xac8f06, 0x918106, 0x9a8907, 0x9c8d09, 0x988e0a, 0x928209, 0x8c7b0b, 0x8f7916, 0x896f1d, 0xa08419, 0xb19012, 0xa77f13, 0x9b7e0a, 0x967b00, 0x9b8802, 0xb39f0f, 0xac9523, 0x97872f, 0x83773a, 0x988740, 0x958036, 0x937e34, 0x9d843b, 0x8c7033, 0x706435, 0x7d6d33, 0x7a6f33, 0x928851, 0x716d35, 0x71682a, 0x7d7032, 0x736b35, 0x857b43, 0x867b46, 0x877c4a, 0x958754, 0xa59360, 0xb7a06e, 0xbaa571, 0xb2a176, 0xb8a87e, 0x786910, 0x877507, 0x948105, 0x837506, 0x958406, 0xa59203, 0x998905, 0xbc9e05, 0xa09003, 0x908206, 0x92820c, 0x8f810d, 0x907b0e, 0x957815, 0x997622, 0xa58123, 0xa7831c, 0xaf7d10, 0xa67712, 0x91792c, 0x9a8c5d, 0x888e76, 0x8f997f, 0x89938f, 0x879099, 0x8f989f, 0x929ba4, 0x909699, 0x90948f, 0x929592, 0x8d908c, 0x91958f, 0x9a9e93, 0xa0a299, 0xb4b3b8, 0x9b9a8f, 0xaaa282, 0xaa9f7b, 0x988d67, 0x92894f, 0x8b823f, 0x898048, 0x918a54, 0xad9d6b, 0xc7b17f, 0xc9b986, 0xc7b589, 0xcfbf92, 0xaa8d10, 0xa89202, 0xa68f04, 0x9c8707, 0x85750c, 0x6c6315, 0x6f660f, 0x73680b, 0xa49106, 0x998a06, 0xb09b05, 0x9a8906, 0x9d880d, 0xb29c0f, 0xab9613, 0x9a8112, 0x8a6f15, 0x8c7532, 0x8a846f, 0x7f909f, 0x6383a4, 0x52749d, 0x42638c, 0x37577e, 0x334f72, 0x304a6c, 0x304767, 0x314968, 0x354b6a, 0x384d6a, 0x3c4f6b, 0x40536c, 0x465972, 0x545e76, 0xa5a5b1, 0xded6da, 0xbeb8bd, 0xafabae, 0xb4b1ac, 0xcac4b4, 0xc5bfa1, 0xa6a06f, 0x908d56, 0x9b9366, 0xb9aa7e, 0xc1b58a, 0xd1c394, 0xe0ce9c, 0x81770d, 0x817607, 0xa28808, 0x86790a, 0x7c710e, 0x6a6510, 0x5d5a0f, 0x796f0c, 0x938305, 0x827c06, 0x827e06, 0x797509, 0x464a18, 0x55590b, 0x606903, 0x8b8b1c, 0x92946a, 0x8b9cb2, 0x6484a8, 0x3f6484, 0x3d5e6f, 0x3d5964, 0x3c525c, 0x364c56, 0x263a4f, 0x25364c, 0x26364a, 0x28384a, 0x293748, 0x2c3b4b, 0x3a4d56, 0x425559, 0x303f4a, 0x616670, 0xd1cac8, 0x798490, 0x4b677e, 0x516f87, 0x597389, 0x677788, 0x878e96, 0xbab8b2, 0xc1bca9, 0xa19d80, 0xa2997a, 0xaea487, 0xc0b393, 0xc7bc97, 0x76680d, 0x82710c, 0xa58212, 0x97810c, 0x81720f, 0x756c11, 0x726a0d, 0x76700f, 0x696a0e, 0x635c12, 0x625a1b, 0x7c7313, 0x615e21, 0x676a57, 0x6a7060, 0x8a999d, 0x8b9eb9, 0x5c788f, 0x365568, 0x3a525d, 0x3f5558, 0x3e5050, 0x3c4e51, 0x32444b, 0x243241, 0x232f3e, 0x283541, 0x25313d, 0x26313c, 0x2c3945, 0x384d56, 0x314650, 0x39414e, 0xbeb8b8, 0x808e9c, 0x305777, 0x375d7e, 0x3c617f, 0x517088, 0x5f788c, 0x5d7489, 0x57687a, 0x90959a, 0xcbc8c2, 0xb7b3a3, 0xa59f84, 0xb0a990, 0xb2ae97, 0x6b6010, 0x685e11, 0x8c6f10, 0x86770e, 0x746816, 0x716113, 0x68610f, 0x605b13, 0x514c0e, 0x4c4310, 0x584c12, 0x564c05, 0x7d794c, 0xa0a5b6, 0x97a3b5, 0x5a718d, 0x3a5064, 0x354950, 0x38494f, 0x354348, 0x354444, 0x374444, 0x384646, 0x29363c, 0x1e2633, 0x25313b, 0x2f3c42, 0x212a34, 0x242d37, 0x26303a, 0x2b3640, 0x24333e, 0x949395, 0x999da5, 0x47637f, 0x8a9fb4, 0x9cacbc, 0x93a4b2, 0x5c7990, 0x597389, 0x5f758a, 0x5a6f89, 0x546c82, 0x747d87, 0xd5d3d0, 0xc3c1b7, 0xabaa94, 0xb2ae9a, 0x625612, 0x544b14, 0x554b12, 0x403a09, 0x3e390a, 0x4a4618, 0x4a4b27, 0x605e33, 0x6f6d3d, 0x747047, 0x7d7850, 0x848050, 0x959485, 0xa9a9b4, 0x6c7887, 0x45535f, 0x45525b, 0x414c56, 0x3e4a51, 0x3e494d, 0x3d494c, 0x3a4447, 0x384145, 0x272f3c, 0x232b39, 0x232d3b, 0x212c3b, 0x202a38, 0x242d3b, 0x1e2631, 0xe1623, 0x585b62, 0xaca9a8, 0x405060, 0x5c6f82, 0x7c848e, 0x7a8089, 0x8f9096, 0x6e7f8d, 0x4d677c, 0x5d6f82, 0x5d6d81, 0x67768a, 0x808690, 0xdfdad4, 0xe3e1df, 0xc7c8c4, 0xb9bab0, 0x585015, 0x60510e, 0x70632a, 0x76745a, 0x8c8c7d, 0xa8a69c, 0xbbb9b3, 0xd1cec7, 0xe7e4dd, 0xf6f2ea, 0xf3f2ed, 0xecedeb, 0xe5e5e6, 0xd5d6d9, 0xc2c7ce, 0xbcc1cb, 0xb2b6c3, 0xa7adbb, 0x9fa6b2, 0xa0a6b2, 0x9ba3b0, 0x9099a7, 0x7f8da1, 0x74839b, 0x6d7c95, 0x6e7c91, 0x727c91, 0x788195, 0x7a8395, 0x727985, 0x636771, 0xb5b2b5, 0x85868b, 0x363e4b, 0x2c323a, 0x494848, 0x848182, 0x908d8f, 0xa1a3a9, 0xadb1b7, 0xb6b6bb, 0xb6b8bc, 0xbab9bb, 0xd3d1ce, 0xe6e1dd, 0xe7e1dd, 0xdfdcda, 0xdedcda, 0x584f18, 0x878263, 0xa2a7ac, 0xb6c0cd, 0xcbd4e2, 0xcdd3e0, 0xd3d8e1, 0xc9d1d9, 0xc4ccd5, 0xbac4cf, 0xb4bfcc, 0xadbac9, 0xaab7c6, 0xa5b5c6, 0xa0b1c2, 0xa2b0c2, 0xb2bbcc, 0xbdc4d1, 0xbec5d2, 0xb3bbc9, 0xadb4c3, 0xa9b3c5, 0xadb7c6, 0xbcc1cd, 0xc8cad4, 0xd3d4d9, 0xdddbdf, 0xe2e1e3, 0xe3e3e4, 0xdedee3, 0xdbdbe0, 0xdcdad9, 0xb4b8c0, 0x3a4f69, 0x565e6a, 0xbebcbc, 0xe7e5e6, 0xe0e0e2, 0xdededf, 0xdadbdd, 0xd9dbdb, 0xd5d6d7, 0xcaced0, 0xc7c9cc, 0xdddad9, 0xe2deda, 0xddd9d7, 0xdddad9, 0x8f8c81, 0x7e89a7, 0x9ea8c1, 0xabb3c2, 0xa8b4c1, 0x96a5bb, 0x91a3b9, 0x92a4ba, 0x94a5bb, 0x96a7bb, 0x95a6bc, 0x95a6bc, 0x95a6bb, 0x99aabd, 0xaab9c8, 0xb7c1d3, 0xa7b2c4, 0x929bae, 0x738095, 0x6b758c, 0x6b748c, 0x6f788f, 0xb3b3bd, 0xe4e1e0, 0xe6e0e0, 0xeeeae9, 0xede9e8, 0xe1dedd, 0xdbd9d7, 0xd7d5d7, 0xd4d3d8, 0xcbcdd2, 0xa1aebe, 0x6d86a4, 0xb4bbc7, 0xd0d0d4, 0xc4c6cb, 0xc2c5ca, 0xbec4c9, 0xc3c7cd, 0x9fa2ab, 0x9b9ba0, 0xbbc0c5, 0xbbbec3, 0xbdbfc5, 0xb1b3ba, 0xc8c6cc, 0xd1d1d2, 0x7e8daa, 0x8589a0, 0xb0b3c2, 0x919db3, 0x8a99b0, 0x8b99b3, 0x8998b3, 0x8999b4, 0x8d9db7, 0x8f9fb9, 0x90a1ba, 0x90a2bb, 0x98a7be, 0xaab6c8, 0x97a4b9, 0x697990, 0x5a6983, 0x394760, 0x5d6377, 0x7b8195, 0x627088, 0xa8acba, 0xc1c3cc, 0xc1c2cb, 0xd5d3d8, 0xa8a9ad, 0x7c7d83, 0x909398, 0x9ca1a7, 0x9fa4ab, 0x9ea2a9, 0xa7abb1, 0xa2aebc, 0xa9b4c3, 0xccccd1, 0xc5c8cc, 0xc3c7cb, 0xc2c5cb, 0xbec2c8, 0xbdc0c7, 0x9b9da6, 0x95989c, 0xb3b8bb, 0xacb2b9, 0x959ba5, 0x989da6, 0x8d8e93, 0x81807e, 0x9a9eb2, 0xb4b9c8, 0x95a1b8, 0x939fb7, 0x95a2b9, 0x8695b0, 0x8696af, 0x95a4bb, 0x95a6bc, 0x98a8c0, 0x97a7c0, 0x9aaac2, 0xa3b3c7, 0xa5afc0, 0x7b8092, 0x697688, 0x848798, 0x6e7385, 0x6f6f7d, 0x818493, 0xa7a9b7, 0xbdbfc9, 0x9ca3b2, 0xa4a9b6, 0x7b7b80, 0x555455, 0x5e5e5d, 0x272d31, 0x71767b, 0x848a93, 0x727983, 0x8a949b, 0x97a0ab, 0x9fa5ae, 0x9ea3ac, 0x959ca6, 0x9199a1, 0x8d949e, 0x878f99, 0x828b94, 0x848c95, 0x858b94, 0x8d9299, 0x8e959c, 0x889199, 0x7f8287, 0x7f7c79, 0x7f7b7a, 0x9399ac, 0x909bb2, 0x8b9bb2, 0x93a0b7, 0x909fb6, 0x6e7ea1, 0x7a8aa5, 0x93a1b6, 0x93a1b8, 0x919fb9, 0x96a6bb, 0x93a5b7, 0x9aaabd, 0x8a96a8, 0x77818f, 0x768191, 0x707c8c, 0x717e90, 0x78899d, 0xb9c1cd, 0xd9d8df, 0xbec0c8, 0x9196a5, 0x6b6970, 0x404043, 0x8e847c, 0x8d8a84, 0x1b2428, 0x343a3d, 0x686e75, 0x575d64, 0x727a85, 0x6c747f, 0x69717f, 0x666e7b, 0x656e7a, 0x656c77, 0x636b76, 0x636b76, 0x636a77, 0x656c76, 0x686e77, 0x6e7179, 0x737981, 0x737981, 0x6e716f, 0x6a6a67, 0x676864, 0x546070, 0x6d788d, 0x717f96, 0x7e8b9f, 0x8793a9, 0x8b98ad, 0x8a98ae, 0x8594a9, 0x8692aa, 0x8a98ae, 0x93a2b4, 0x919fb1, 0x8898ac, 0x8898ae, 0x7f91a7, 0x5f6e83, 0x576778, 0x505c6c, 0x39444f, 0x898a90, 0xcacbd2, 0xb4b9c3, 0x8c747b, 0x2e2225, 0x212528, 0x746f6c, 0x5e5f64, 0x262f34, 0x1b2326, 0x4a5055, 0x424a53, 0x565f69, 0x535c66, 0x505a64, 0x4e5762, 0x4e5761, 0x515964, 0x525a64, 0x545c66, 0x585f68, 0x585f68, 0x575c64, 0x5f6268, 0x6c7078, 0x686c72, 0x585b5a, 0x636362, 0x656362, 0x27282e, 0x292933, 0x292d34, 0x2c333a, 0x31353d, 0x32373e, 0x333840, 0x30353f, 0x2e333d, 0x31363e, 0x313641, 0x30363f, 0x2e353d, 0x333a44, 0x818a96, 0x7f8691, 0x7c8187, 0x6f7076, 0x27292f, 0x2c2e32, 0xa3a4a9, 0x98a0aa, 0x4a3a3f, 0x1b1b1f, 0x202227, 0x5a5856, 0x646667, 0x1e282d, 0x192024, 0x3f454a, 0x434b53, 0x475159, 0x47505a, 0x454d58, 0x444c57, 0x434d55, 0x424a54, 0x414a54, 0x404953, 0x3f4751, 0x4c5159, 0x6a6d75, 0x6a6e76, 0x64696e, 0x505253, 0x5a5958, 0x6a6869, 0x828080, 0x292b2e, 0x1f1e22, 0x1c1d20, 0x1a1d20, 0x191d1f, 0x1b1f20, 0x1d2121, 0x1e2122, 0x1f2122, 0x202023, 0x1d2022, 0x1d2022, 0x18181b, 0x454749, 0x7d7c7b, 0x726f6b, 0x6f6a67, 0x52504e, 0x1c1f24, 0x1e2228, 0x5d6065, 0x717981, 0x27282d, 0x1b1c1f, 0x202226, 0x51514f, 0x58585c, 0x192027, 0x171e23, 0x4b5056, 0x434b55, 0x2a343d, 0x2e3641, 0x29323c, 0x28323b, 0x2c343e, 0x363e48, 0x444c54, 0x51575f, 0x70757a, 0xb1b2b5, 0xb0b1b4, 0x707278, 0x5a5b5f, 0x4d4c47, 0x73726e, 0x707072, 0x606061, 0x404042, 0x1e2025, 0x202226, 0x1c2022, 0x1d2122, 0x1e2224, 0x202225, 0x212527, 0x222629, 0x232728, 0x24282a, 0x25292b, 0x2e3135, 0x626363, 0x736e69, 0x74706a, 0x7a7774, 0x4f5053, 0x16181d, 0x1c1c21, 0x484d53, 0x58636b, 0x1f2227, 0x171c1d, 0x1c1f20, 0x817c77, 0x55585d, 0x1f262c, 0x151d21, 0x4d525a, 0x636a71, 0x686d72, 0x6d7276, 0x7b7e81, 0x85898d, 0x8f9195, 0x929498, 0x959698, 0xa1a0a1, 0xaeacad, 0x8b8c8c, 0x535251, 0x504b4b, 0x52504f, 0x484744, 0x5a5b59, 0x5a5a5a, 0x6a6b6e, 0x272a2d, 0x1d1e21, 0x1c1e21, 0x1a1c1e, 0x191d1e, 0x1b1d1f, 0x1c1d21, 0x181c20, 0x171b1f, 0x171a1f, 0x181b1f, 0x181a1e, 0x1d1f24, 0x45474b, 0x798289, 0x84919c, 0x909cad, 0x5e697b, 0x101119, 0x2d2f34, 0x565b61, 0x3b4146, 0x1c1d21, 0x191b1d, 0x171b1c, 0x6f6d68, 0x4d5354, 0x1a2127, 0x262c2f, 0x54595d, 0x5b5f64, 0x7f7e80, 0x7f7e7e, 0x787778, 0x737172, 0x6d6c6d, 0x676869, 0x68696d, 0x6a6c6f, 0x64676d, 0x65686c, 0x818085, 0x6b6969, 0x434139, 0x4b4943, 0x6b6a67, 0x858483, 0xa0a2a2, 0x62564a, 0x292726, 0x181a1d, 0x1a1e1f, 0x181c1d, 0x1a1b1e, 0x181a1d, 0x212325, 0x282a2a, 0x292829, 0x272629, 0x2f2d2f, 0x39393c, 0x3b3f41, 0x44484c, 0x616871, 0x6d727a, 0x606468, 0x575959, 0x555555, 0x4e4b49, 0x353636, 0x17191d, 0x161a1b, 0x181a1b, 0x555556, 0x4c5051, 0x14181c, 0x212627, 0x404343, 0x63676b, 0x575b5d, 0x525552, 0x4f514e, 0x555653, 0x5d5f5d, 0x5e6265, 0x61646a, 0x666a71, 0x646c73, 0x7a7e86, 0x858990, 0x696b6f, 0x42403c, 0x403e36, 0x525048, 0x85837d, 0x969996, 0xc7a486, 0x504840, 0x14171b, 0x191c1e, 0x16171a, 0x16161a, 0x101216, 0x736c5e, 0x968a74, 0x8a7e6e, 0x847a6b, 0x817a6a, 0x7b7568, 0x726d63, 0x645f56, 0x59544b, 0x514b43, 0x4d473f, 0x48463f, 0x41403c, 0x393834, 0x242726, 0x111517, 0x141619, 0x111415, 0x57524d, 0x2c2e31, 0xb1011, 0xf1416, 0x1c2224, 0x2a2f31, 0x282a29, 0x2c2e2b, 0x2c2f2c, 0x282a27, 0x232423, 0x262724, 0x2c2c2b, 0x333331, 0x3a3c37, 0x3f403c, 0x44453f, 0x4e4e49, 0x5a5953, 0x5a5a51, 0x595950, 0x5d5c54, 0x605e55, 0xab927b, 0x827764, 0x191b1c, 0xf1116, 0xf1115, 0xc0e13, 0x15171a, 0x47423e, 0x45413b, 0x383633, 0x31312c, 0x272826, 0x1e2021, 0x1d1f20, 0x1a1c1c, 0x181a1a, 0x141617, 0x101314, 0x141314, 0x151718, 0x1e1f1e, 0x272726, 0x2c2c28, 0x32312c, 0x373631, 0x4f4b43, 0x44443b, 0x45443e, 0x45453f, 0x43433d, 0x464640, 0x4c4d47, 0x4c4c45, 0x4a4c45, 0x4b4d47, 0x4e4f48, 0x50504a, 0x53534e, 0x5a5a53, 0x5d5e56, 0x5b5c55, 0x5c5c55, 0x5e5e56, 0x5b5a54, 0x5a5953, 0x5a5a51, 0x5e5d54, 0x65655b, 0x373634, 0x302f2f, 0x242325, 0x222223, 0x222223, 0x242424, 0x262526, 0x272625, 0x262625, 0x2e2d2b, 0x393834, 0x3f3d38, 0x403e38, 0x41403a, 0x4c4940, 0x545147, 0x5a574b, 0x5e5b50, 0x5f5a50, 0x5b574c, 0x59564a, 0x565247, 0x565247, 0x59564b, 0x58574b, 0x4e4d42, 0x504f44, 0x4a4a3f, 0x4b4b42, 0x4f4f46, 0x55554c, 0x505247, 0x4f5247, 0x4f504a, 0x4f504a, 0x4f5048, 0x4b4b45, 0x4a4943, 0x4b4b45, 0x484942, 0x4a4b44, 0x4e4e48, 0x53524d, 0x575750, 0x5b5c56, 0x616059, 0x626159, 0x636156, 0x665f57, 0x6c655d, 0x6f685e, 0x6b6559, 0x6a6559, 0x6c675b, 0x6e695c, 0x6f695c, 0x6f695c, 0x6b6559, 0x666054, 0x625d51, 0x605b4f, 0x5c574a, 0x575246, 0x575247, 0x565347, 0x565247, 0x585449, 0x575348, 0x585447, 0x575247, 0x575348, 0x575347, 0x5b594d, 0x5f5d50, 0x585649, 0x525146, 0x4e4e44, 0x494941, 0x4c4c41, 0x46473d, 0x44453a, 0x44443b, 0x45463d, 0x45463f, 0x464540, 0x4f4f46, 0x515147, 0x4e4e47, 0x53524b, 0x53534e, 0x52524d, 0x51504a, 0x4e4f49, 0x5a5952, 0x615f56, 0x66645b, 0x6b6559, 0x655d53, 0x615a50, 0x5c574d, 0x5a5448, 0x555045, 0x5a564b, 0x555146, 0x555046, 0x595449, 0x555146, 0x575347, 0x5c574b, 0x5a5549, 0x535043, 0x595647, 0x5c594b, 0x5c584b, 0x5b584b, 0x5d584d, 0x5f5b4f, 0x5d5a4e, 0x555146, 0x4c483d, 0x4a493d, 0x45463b, 0x424238, 0x46463b, 0x45463c, 0x494a3f, 0x4e4c42, 0x4b4a41, 0x504d43, 0x4d4d43, 0x4c4d45, 0x505047, 0x4b4b42, 0x4e4e43, 0x4e4e46, 0x54554d, 0x585951, 0x585951, 0x5b5b54, 0x5b5c54, 0x5f6058, 0x66665d, 0x69695f, 0x6b6b61, 0x5c564a, 0x5e574d, 0x575047, 0x5e574b, 0x686255, 0x666154, 0x605a4e, 0x625d4f, 0x5c564a, 0x5f584c, 0x5e584b, 0x5c5549, 0x605a4e, 0x615c50, 0x5d584c, 0x5d574c, 0x585346, 0x524d42, 0x4a463c, 0x49453a, 0x48453a, 0x4f4c41, 0x4e4b40, 0x514d42, 0x545245, 0x535045, 0x524e44, 0x4f4e42, 0x514f45, 0x525145, 0x545345, 0x535246, 0x58564a, 0x59574b, 0x5a5a4f, 0x5d5c53, 0x5a5b50, 0x5a584d, 0x605f55, 0x5b5c53, 0x5e5e55, 0x62625a, 0x5f5f58, 0x606059, 0x64645c, 0x696960, 0x66665e, 0x66665e, 0x625a4f, 0x5f584d, 0x585247, 0x5d574a, 0x5e574c, 0x5d564b, 0x585246, 0x605a4c, 0x5f5a4e, 0x5e574c, 0x5d574c, 0x5a5549, 0x4f4b40, 0x4e493c, 0x514c40, 0x514d41, 0x5e5a4d, 0x575347, 0x555045, 0x625c4f, 0x656054, 0x645f52, 0x595548, 0x5f5a4e, 0x605a4e, 0x646053, 0x625e53, 0x626053, 0x5f5e51, 0x646155, 0x626153, 0x636154, 0x5e5b52, 0x605e51, 0x5d5b51, 0x646259, 0x606056, 0x59594f, 0x66665c, 0x61635a, 0x5b5c55, 0x64655e, 0x65655d, 0x61615a, 0x626259, 0x66665e, 0x696961, 0x6a6b64, 0x5c5449, 0x5e584d, 0x5c574c, 0x5c564a, 0x575042, 0x554b44, 0x595249, 0x625b4f, 0x5d564b, 0x655f52, 0x645e52, 0x665f53, 0x676254, 0x696354, 0x6a6354, 0x656050, 0x686255, 0x6b6558, 0x6a6355, 0x706958, 0x706a5a, 0x716b5d, 0x686152, 0x696354, 0x6e685b, 0x696558, 0x676356, 0x625e52, 0x5f5c50, 0x605b51, 0x615e53, 0x605c51, 0x615f54, 0x5e5c53, 0x666259, 0x5c5b52, 0x5e5f54, 0x616056, 0x64655b, 0x64655b, 0x616158, 0x66665e, 0x65655d, 0x5f6157, 0x63645b, 0x63645c, 0x676860, 0x676862, 0x625a50, 0x635b51, 0x615b4e, 0x666052, 0x6a6354, 0x70695b, 0x756f5f, 0x706a5a, 0x746d5d, 0x706859, 0x736e5c, 0x736b5d, 0x736c5c, 0x6d6558, 0x716a5b, 0x746d5e, 0x746e5f, 0x736b5d, 0x706a5a, 0x706a57, 0x6c6656, 0x666254, 0x625f51, 0x625c4f, 0x686156, 0x615c4e, 0x635f53, 0x676357, 0x666155, 0x605b4f, 0x656055, 0x615e52, 0x5f5d52, 0x625f56, 0x625f57, 0x5d5a51, 0x625f56, 0x605c53, 0x58564d, 0x5c5d53, 0x5a5a53, 0x636159, 0x606057, 0x616258, 0x616158, 0x5f5f57, 0x606058, 0x67675f, 0x787162, 0x756e61, 0x766e61, 0x787162, 0x797262, 0x766f5d, 0x756e5d, 0x6c6558, 0x746d5c, 0x6a6356, 0x716a5b, 0x736b5e, 0x70685c, 0x766e60, 0x746d5c, 0x746d5b, 0x6f685a, 0x746e5d, 0x6c6656, 0x696252, 0x6a6456, 0x6d6759, 0x665f52, 0x666053, 0x635d50, 0x645e51, 0x625e52, 0x646054, 0x5e5b4f, 0x5e594e, 0x615b50, 0x625f53, 0x615d52, 0x5d5d50, 0x646258, 0x5e5a4f, 0x5f5b52, 0x686559, 0x5e5b50, 0x626156, 0x5f5f58, 0x615f56, 0x626258, 0x66665c, 0x66665b, 0x67675e, 0x6a6961, 0x6e6e63, 0x726b5c, 0x71695d, 0x6f675c, 0x70685a, 0x6d6557, 0x797361, 0x766e5f, 0x71695d, 0x6c6557, 0x716b5b, 0x6e675a, 0x70695d, 0x756f62, 0x6f675c, 0x6f6758, 0x6f6857, 0x736d5c, 0x6a6355, 0x645d50, 0x6e6758, 0x6b6556, 0x686455, 0x635e52, 0x645e51, 0x666054, 0x635e52, 0x625e52, 0x615d51, 0x5b574c, 0x635e54, 0x635f54, 0x645e54, 0x615d52, 0x5b594d, 0x666357, 0x666358, 0x615e55, 0x6a665c, 0x6c6a5d, 0x6c6b61, 0x6d6b61, 0x6f6d63, 0x717067, 0x6f6f65, 0x6b6a60, 0x6d6c63, 0x6b6a62, 0x65655f, 0x6a6455, 0x676054, 0x726c5c, 0x776f5f, 0x6e6658, 0x726b5b, 0x6d6457, 0x736c5d, 0x756f5e, 0x766e60, 0x726b5e, 0x706a5c, 0x676053, 0x635c4f, 0x686054, 0x6c6656, 0x726b5a, 0x696152, 0x696254, 0x6a6454, 0x6e6858, 0x696258, 0x665f54, 0x6a6457, 0x655f52, 0x655f53, 0x635e53, 0x615d51, 0x615d52, 0x5f5c51, 0x696559, 0x655f55, 0x676358, 0x676358, 0x68655a, 0x6a695d, 0x6e6a60, 0x6f6d64, 0x6e6c60, 0x726f63, 0x716d62, 0x716d63, 0x6c6960, 0x626058, 0x66635b, 0x58564f, 0x55554e, 0x55544e, 0x777061, 0x716a5a, 0x696254, 0x6e675a, 0x5f5a4f, 0x6b6555, 0x6e6656, 0x726a5b, 0x6f6858, 0x696255, 0x6f685a, 0x696154, 0x625b4f, 0x6d6557, 0x6c6657, 0x645e51, 0x6d6656, 0x6d6656, 0x675f51, 0x696254, 0x676154, 0x6c6357, 0x726a5f, 0x6b6658, 0x676153, 0x645f53, 0x6c675c, 0x6c685c, 0x6e6a5e, 0x706a5d, 0x736e62, 0x737165, 0x726f63, 0x6a675b, 0x6c685b, 0x6f6b5e, 0x6b665a, 0x655f56, 0x5b574e, 0x5d584e, 0x6f695f, 0x71685e, 0x73695d, 0x6a6359, 0x7d766c, 0x746c60, 0x796e61, 0x776c5f, 0x6b6356, 0x6c6457, 0x615b4e, 0x645d52, 0x615b51, 0x686253, 0x726b5a, 0x726b5d, 0x676153, 0x655f50, 0x686053, 0x635d51, 0x655d51, 0x6d645a, 0x6d675a, 0x645f52, 0x6a6356, 0x686152, 0x6e6758, 0x6b6556, 0x676152, 0x6a6256, 0x6c6459, 0x70685c, 0x746d60, 0x6d675a, 0x6c675a, 0x6f6a5e, 0x6a6757, 0x706b5d, 0x666359, 0x57554c, 0x5f5b51, 0x5b574e, 0x5a574d, 0x555046, 0x585247, 0x5d564b, 0x555045, 0x565048, 0x5e5650, 0x5e554c, 0x5e544a, 0x534b43, 0x534c46, 0x4c4942, 0x48423b, 0x3e3b35, 0x645b50, 0x6c6358, 0x6f675b, 0x655e53, 0x625c4f, 0x70695b, 0x6c6354, 0x6d6756, 0x696256, 0x6d6558, 0x6e6658, 0x6a6255, 0x696156, 0x675f54, 0x5b564a, 0x5d5b4e, 0x615e52, 0x5f594f, 0x585249, 0x575347, 0x575348, 0x4f4b42, 0x4c4740, 0x49483f, 0x46423b, 0x3c3b35, 0x373832, 0x373832, 0x2e2f29, 0x2b2b28, 0x202121, 0x1a1a1b, 0x1d1d1d, 0x18181a, 0x161719, 0x141516, 0x151617, 0x171618, 0x171419, 0x17161a, 0x15141a, 0x131419, 0x131518, 0x151419, 0x151318, 0x141316, 0x151419, 0x121316
* @brief Copy raw feature data in out_ptr
* Function called by inference library
* @param[in] offset The offset
* @param[in] length The length
* @param out_ptr The out pointer
* @return 0
int raw_feature_get_data(size_t offset, size_t length, float *out_ptr) {
memcpy(out_ptr, features + offset, length * sizeof(float));
return 0;
void r565_to_rgb(uint16_t color, uint8_t *r, uint8_t *g, uint8_t *b) {
*r = (color & 0xF800) >> 8;
*g = (color & 0x07E0) >> 3;
*b = (color & 0x1F) << 3;
int cutout_get_data(size_t offset, size_t length, float *out_ptr) {
// so offset and length naturally operate on the *cutout*, so we need to cut it out from the real framebuffer
size_t bytes_left = length;
size_t out_ptr_ix = 0;
// read byte for byte
while (bytes_left != 0) {
// find location of the byte in the cutout
size_t cutout_row = floor(offset / CUTOUT_COLS);
size_t cutout_col = offset - (cutout_row * CUTOUT_COLS);
// then read the value from the real frame buffer
size_t frame_buffer_row = cutout_row + cutout_row_start;
size_t frame_buffer_col = cutout_col + cutout_col_start;
// grab the value and convert to r/g/b
uint16_t pixel = frame_buffer[(frame_buffer_row * FRAME_BUFFER_COLS) + frame_buffer_col];
uint8_t r, g, b;
r565_to_rgb(pixel, &r, &g, &b);
// then convert to out_ptr format
float pixel_f = (r << 16) + (g << 8) + b;
out_ptr[out_ptr_ix] = pixel_f;
// and go to the next pixel
out_ptr_ix++;
offset++;
bytes_left--;
// and done!
return 0;
* @brief Arduino setup function
void setup()
// put your setup code here, to run once:
Serial.begin(115200);
Serial.println("Edge Impulse Inferencing Demo");
* @brief Arduino main function
void loop()
ei_printf("Edge Impulse standalone inferencing (Arduino)\n");
if (sizeof(features) / sizeof(float) != EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE) {
ei_printf("The size of your 'features' array is not correct. Expected %lu items, but had %lu\n",
EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE, sizeof(features) / sizeof(float));
delay(1000);
return;
ei_impulse_result_t result = { 0 };
// the features are stored into flash, and we don't want to load everything into RAM
signal_t features_signal;
features_signal.total_length = sizeof(features) / sizeof(features[0]);
//features_signal.get_data = &raw_feature_get_data;
features_signal.get_data = &cutout_get_data;
// invoke the impulse
EI_IMPULSE_ERROR res = run_classifier(&features_signal, &result, false /* debug */);
ei_printf("run_classifier returned: %d\n", res);
if (res != 0) return;
// print the predictions
ei_printf("Predictions ");
ei_printf("(DSP: %d ms., Classification: %d ms., Anomaly: %d ms.)",
result.timing.dsp, result.timing.classification, result.timing.anomaly);
ei_printf(": \n");
ei_printf("[");
for (size_t ix = 0; ix < EI_CLASSIFIER_LABEL_COUNT; ix++) {
ei_printf("%.5f", result.classification[ix].value);
#if EI_CLASSIFIER_HAS_ANOMALY == 1
ei_printf(", ");
#else
if (ix != EI_CLASSIFIER_LABEL_COUNT - 1) {
ei_printf(", ");
#endif
ei_printf("%.3f", result.anomaly);
#endif
ei_printf("]\n");
// human-readable predictions
ei_printf(" %s: %.5f\n", result.classification[ix].label, result.classification[ix].value);
ei_printf(" anomaly score: %.3f\n", result.anomaly);
#endif
delay(1000);
* @brief Printf function uses vsnprintf and output using Arduino Serial
* @param[in] format Variable argument list
void ei_printf(const char *format, ...) {
static char print_buf[1024] = { 0 };
va_list args;
va_start(args, format);
int r = vsnprintf(print_buf, sizeof(print_buf), format, args);
va_end(args);
if (r > 0) {
Serial.write(print_buf);
My model is trained in grayscale with 48x48 resolution.
Any thoughts please ?
You guys are incredible. I want to you know that I have successfully deployed the edge impulse project to the esp32cam development board (uninstall and re install Arduino and platform.local.txt helped a lot.
After copying raw data in the project and deploying it successfully, I didn’t see the desired result in the serial monitor. As shown in the figure below. Is it the wrong data I copied, or something else?
Hi @jiffy, it cannot allocate a buffer large enough to run the neural network calculations. How large is the model that you created (as it states on the Deployment page)? Probably pick a smaller transfer learning model or set the size of your image to a lower resolution (on Create impulse page).
I’m not sure how much RAM is usable, but I’d try:
- Resize to 48x48
- Pick the MobileNetV2 0.05 transfer learning model
- Make sure to enable EON when creating the C++ library
And see if that works, then start making the model larger again.
@janjongboom thanks a lot. these suggestions really worked. now it can work well with the static_buffer. My problem is, if I want to read images in real time for classification, instead of using static_ buffer, is the size limit still in place?
@jifly, well, you’re limited by the amount of RAM and flash that can be used on the ESP32Cam, so yes, still in place (maybe even a bit less because you need to allocate a framebuffer for the video somewhere)… I think this is helpful too: https://github.com/edgeimpulse/example-signal-from-rgb565-frame-buffer
Hi, Jan.
I have a problem with the esp32 cam board as follows:
how to solve it please help me.
thank you, Rizki
Hi @rizkiosb your model is too big. You can swap out the transfer learning model for the 0.1 model for example via Impulse design > Transfer learning and then ‘Choose a different
model’.
