Hi, I’m trying compile the arduino example of my proyect in ESP32 S3
Project ID:156286
Using this configuration:
And the log is this:
Arduino:1.8.19 (Windows 10), Tarjeta:“ESP32S3 Dev Module, OPI PSRAM, QIO 80MHz, 8MB (64Mb), Core 1, Core 1, Hardware CDC and JTAG, Disabled, Disabled, Disabled, UART0 / Hardware CDC, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi), 921600, None, Disabled”
c:/users/cvega/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/…/lib/gcc/xtensa-esp32s3-elf/8.4.0/…/…/…/…/xtensa-esp32s3-elf/bin/ld.exe: libraries\Sound_test_inferencing\edge-impulse-sdk\porting\espressif\ESP-NN\src\convolution\objs.a(esp_nn_conv_esp32s3.c.o):(.literal.esp_nn_conv_s8_esp32s3+0x8): undefined reference to `esp_nn_conv_s8_mult8_1x1_esp32s3’
c:/users/cvega/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/…/lib/gcc/xtensa-esp32s3-elf/8.4.0/…/…/…/…/xtensa-esp32s3-elf/bin/ld.exe: libraries\Sound_test_inferencing\edge-impulse-sdk\porting\espressif\ESP-NN\src\convolution\objs.a(esp_nn_conv_esp32s3.c.o):(.literal.esp_nn_conv_s8_esp32s3+0xc): undefined reference to `esp_nn_s8_to_s16_esp32s3’
c:/users/cvega/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/…/lib/gcc/xtensa-esp32s3-elf/8.4.0/…/…/…/…/xtensa-esp32s3-elf/bin/ld.exe: libraries\Sound_test_inferencing\edge-impulse-sdk\porting\espressif\ESP-NN\src\convolution\objs.a(esp_nn_conv_esp32s3.c.o):(.literal.esp_nn_conv_s8_esp32s3+0x10): undefined reference to `esp_nn_aligned_s8_to_s16_with_offset_esp32s3’
c:/users/cvega/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/…/lib/gcc/xtensa-esp32s3-elf/8.4.0/…/…/…/…/xtensa-esp32s3-elf/bin/ld.exe: libraries\Sound_test_inferencing\edge-impulse-sdk\porting\espressif\ESP-NN\src\convolution\objs.a(esp_nn_conv_esp32s3.c.o):(.literal.esp_nn_conv_s8_esp32s3+0x14): undefined reference to `esp_nn_conv_s16_mult4_1x1_esp32s3’
c:/users/cvega/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/…/lib/gcc/xtensa-esp32s3-elf/8.4.0/…/…/…/…/xtensa-esp32s3-elf/bin/ld.exe: libraries\Sound_test_inferencing\edge-impulse-sdk\porting\espressif\ESP-NN\src\convolution\objs.a(esp_nn_conv_esp32s3.c.o):(.literal.esp_nn_conv_s8_esp32s3+0x18): undefined reference to `esp_nn_conv_s16_mult8_esp32s3’
c:/users/cvega/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/…/lib/gcc/xtensa-esp32s3-elf/8.4.0/…/…/…/…/xtensa-esp32s3-elf/bin/ld.exe: libraries\Sound_test_inferencing\edge-impulse-sdk\porting\espressif\ESP-NN\src\convolution\objs.a(esp_nn_conv_esp32s3.c.o): in function `esp_nn_conv_s8_esp32s3’:
D:\Documents\Arduino\libraries\Sound_test_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\convolution/esp_nn_conv_esp32s3.c:422: undefined reference to `esp_nn_conv_s8_mult8_1x1_esp32s3’
c:/users/cvega/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/…/lib/gcc/xtensa-esp32s3-elf/8.4.0/…/…/…/…/xtensa-esp32s3-elf/bin/ld.exe: D:\Documents\Arduino\libraries\Sound_test_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\convolution/esp_nn_conv_esp32s3.c:431: undefined reference to `esp_nn_s8_to_s16_esp32s3’
c:/users/cvega/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/…/lib/gcc/xtensa-esp32s3-elf/8.4.0/…/…/…/…/xtensa-esp32s3-elf/bin/ld.exe: D:\Documents\Arduino\libraries\Sound_test_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\convolution/esp_nn_conv_esp32s3.c:432: undefined reference to `esp_nn_aligned_s8_to_s16_with_offset_esp32s3’
c:/users/cvega/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/…/lib/gcc/xtensa-esp32s3-elf/8.4.0/…/…/…/…/xtensa-esp32s3-elf/bin/ld.exe: D:\Documents\Arduino\libraries\Sound_test_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\convolution/esp_nn_conv_esp32s3.c:433: undefined reference to `esp_nn_conv_s16_mult4_1x1_esp32s3’
c:/users/cvega/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/…/lib/gcc/xtensa-esp32s3-elf/8.4.0/…/…/…/…/xtensa-esp32s3-elf/bin/ld.exe: D:\Documents\Arduino\libraries\Sound_test_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\convolution/esp_nn_conv_esp32s3.c:438: undefined reference to `esp_nn_s8_to_s16_esp32s3’
c:/users/cvega/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/…/lib/gcc/xtensa-esp32s3-elf/8.4.0/…/…/…/…/xtensa-esp32s3-elf/bin/ld.exe: D:\Documents\Arduino\libraries\Sound_test_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\convolution/esp_nn_conv_esp32s3.c:439: undefined reference to `esp_nn_aligned_s8_to_s16_with_offset_esp32s3’
c:/users/cvega/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/…/lib/gcc/xtensa-esp32s3-elf/8.4.0/…/…/…/…/xtensa-esp32s3-elf/bin/ld.exe: D:\Documents\Arduino\libraries\Sound_test_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\convolution/esp_nn_conv_esp32s3.c:440: undefined reference to `esp_nn_conv_s16_mult8_esp32s3’
c:/users/cvega/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/…/lib/gcc/xtensa-esp32s3-elf/8.4.0/…/…/…/…/xtensa-esp32s3-elf/bin/ld.exe: libraries\Sound_test_inferencing\edge-impulse-sdk\tensorflow\lite\micro\kernels\objs.a(fully_connected.cpp.o):(.literal._ZN6tflite12_GLOBAL__N_14EvalEP13TfLiteContextP10TfLiteNode+0x8): undefined reference to `esp_nn_fully_connected_s8_esp32s3’
c:/users/cvega/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/…/lib/gcc/xtensa-esp32s3-elf/8.4.0/…/…/…/…/xtensa-esp32s3-elf/bin/ld.exe: libraries\Sound_test_inferencing\edge-impulse-sdk\tensorflow\lite\micro\kernels\objs.a(fully_connected.cpp.o): in function `tflite::(anonymous namespace)::Eval(TfLiteContext*, TfLiteNode*)’:
D:\Documents\Arduino\libraries\Sound_test_inferencing\src\edge-impulse-sdk\tensorflow\lite\micro\kernels/fully_connected.cpp:1272: undefined reference to `esp_nn_fully_connected_s8_esp32s3’
c:/users/cvega/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/…/lib/gcc/xtensa-esp32s3-elf/8.4.0/…/…/…/…/xtensa-esp32s3-elf/bin/ld.exe: libraries\Sound_test_inferencing\edge-impulse-sdk\tensorflow\lite\micro\kernels\objs.a(pooling.cpp.o):(.literal._ZN6tflite3ops5micro7pooling7MaxEvalEP13TfLiteContextP10TfLiteNode+0x8): undefined reference to `esp_nn_max_pool_s8_esp32s3’
c:/users/cvega/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/…/lib/gcc/xtensa-esp32s3-elf/8.4.0/…/…/…/…/xtensa-esp32s3-elf/bin/ld.exe: libraries\Sound_test_inferencing\edge-impulse-sdk\tensorflow\lite\micro\kernels\objs.a(pooling.cpp.o): in function `tflite::ops::micro::pooling::MaxEval(TfLiteContext*, TfLiteNode*)’:
D:\Documents\Arduino\libraries\Sound_test_inferencing\src\edge-impulse-sdk\tensorflow\lite\micro\kernels/pooling.cpp:1485: undefined reference to `esp_nn_max_pool_s8_esp32s3’
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compilando para la tarjeta ESP32S3 Dev Module.
