This is in relation to my EI project - anupamguptacal-project-1
I’ve been trying to use Edge Impulse to train an object detection model. I have a trained model and translated it to an Arduino Library for deployment. I’m deploying to an ESP32 CAM and have already validated that the example from here: https://github.com/edgeimpulse/example-esp32-cam works correctly post deployment and provides good accuracy.
All I’m doing post this point, is replacing their included library with the Arduino Library I created for my project but I keep facing this problem with some of the fields of the structs not being recognized(during compilation). Specifically the following:
Basic-Image-Classification:164:42: error: 'struct ei_impulse_result_t' has no member named 'classification'
ei_printf(" %s: \t%f\r\n", result.classification[ix].label, result.classification[ix].value);
and
anupamguptacal-project-1_inferencing\src/edge-impulse-sdk/classifier/ei_run_classifier.h:588:93: error: 'post_process_classes' is not a member of 'tflite'
fill_result_struct_f32(result, tflite::post_process_boxes, tflite::post_process_scores, tflite::post_process_classes, debug);
and
anupamguptacal-project-1_inferencing\src/edge-impulse-sdk/classifier/ei_run_classifier.h:588:64: error: 'post_process_scores' is not a member of 'tflite'
My understanding of Object Detection is that it does both Bounding Boxes as well as Classification (I’ve validated this is as expected under the Live Classification Section of the website).
I did some digging around and it seems that in the file ei_classifier_types.cpp in the library, ei_impulse_result_classification_t classification[EI_CLASSIFIER_LABEL_COUNT] is not set if the EI_CLASSIFIER_OBJECT_DETECTION flag is set as 1. I also see that in my model_metadata file, I have the following flags set:
#define EI_CLASSIFIER_OBJECT_DETECTION 1
#define EI_CLASSIFIER_OBJECT_DETECTION_COUNT 10
#define EI_CLASSIFIER_OBJECT_DETECTION_THRESHOLD 0.5
#define EI_CLASSIFIER_TFLITE_OUTPUT_LABELS_TENSOR 1
#define EI_CLASSIFIER_TFLITE_OUTPUT_SCORE_TENSOR 2
I haven’t dived into the tensor flow errors but maybe it’s something similar. I guess my question is: What am I doing wrong? Is there an example I can follow that defines how to use object detection models with the Arduino IDE? Or did I deploy my model incorrectly in the first place itself and I need to undo something?
Any advice in this regard would be really helpful. Thank you!
